As mentioned in a previous post, I had the Nova out to the track for the first time, and it ran very well. I managed to get a 13.80 @ 101.5 out of it in spite of constant tranny problems - it would not go to third except for two of the ten runs I made. Those times it did go were in Drive, and the shift occurred immediately after it went to second. It has a B&M Shift Kit, Pro-Matic 2 shifter, and all adjustable stuff is right on (kickdown, shift cable). It will go to third in conditions other than WOT. I can feel that shift on the way back to the pit area. The modulator has good vacuum thru a hard line, and I turned it out four turns from the bottom as a start point. Any help will be very much appreciated. Thanks in advance.
