1 - 20 of 65 Posts
Owner: Tim "SkySkrape" Katz Vice President/Co Founder
TAPOUT LLC
Builders:
Demented Customs
Full Throttle Kustomz
Go-Ez Customs
List of vendors helping with the project:
Becool Aluminum Radiator
Currie F9 housing, 35 spline axles(boost is in this engines future), 3.70 Platinum Trac, billet yoke, billet pinion support
GM Performance Parts E-Rod Crate engine
Total Cost Involved Pro-Touring front clip & Torque Arm rear Suspension
Tremec 6 speed
Wilwood 14" 6 piston front, 14" 4 piston rear
Planned completion date is SEMA 2011. First track day will be the Optima Challenge with Tim at the helm.
Tim has a busy week with the Nationwide race in Florida and UFC 132 in Vegas but next week the thrashing begins.
A little moch up picture with a 315/30/18 :yes:
-J
I haven't posted updates in a while so here we go.
The builders listed above fell thru so "The GMR" picked up the build. They cut off the standard rear axle housing flanges and installed their full floater set-up. They also cut out the existing cage and built a new one that tucks up tighter and hides behind the posts a little beteter. The car goes to Magnaflow next week so they can mount the Turbo and build the exhaust.
-J
This BEAST is just flat out FINE but the $$$$$$$$$$$$$$ would kill me. Keep the pic's coming...Jack
Discussion Starter · #9 ·
Tail lights look nice!
Is that a 3 link in the back with a torque arm? Any particular reason you went that route?
It is a TCI Torque Arm. Packaging is primary reason Tim went this way. He wanted something that was going to perform well at the autocross and have great street manners.
The day @ Magnaflow with Hot Rod TV filming was great.
Turbonetics supplied 76mm Inducer Compressor/75mm Exducer exhaust/1.01 A/R
Turbonetics New Gen Wastegate & Godzilla BOV
Pushed into the corner & ready for the exhaust
Some pics of the new cage.
Hooker supplied these epic cast exhaust manifolds. They are great for tight packaging and turbo applications.
A couple shots before Magnaflow got to work.
Reggie from Turbonetics talking to Tim about turbocharging
Left to Right: Tim(Owner), Reggie(Turbonetics), Richard(MagnaFlow), & Jason (The GMR)
Starting on the driver's side exhaust
Final turbo placement may be slightly different because the radiator wasn't mounted yet.
The car was up on the lift so I snapped a pic of the rearend.
Jason from 'The GMR' talking to the camera about his full floater hubs on the Currie rearend.
Yours truly putting on his serious face for the camera.
-J
Discussion Starter · #10 · (Edited)
Jose Cruz from MagnaFlow starts building the downpipe and exhaust system.
Tim's good friend and resident goofball Jeff Long looking on while tack welds are placed on the exhaust.
We ran out of daylight so we just dropped the car down and let Hot Rod TV finish up their portion of filming.
-J
Discussion Starter · #14 ·
This thread was a copy & paste from the other forum but yes I do work for one of the suppliers. If I am overstepping any advertising rule boundaries just let me know.
-J
Discussion Starter · #16 ·
I actually think I tried editing the first post a while back but there is no 'Edit' button. If you feel something needs to be removed by all means go for it.
-J
Discussion Starter · #17 ·
I stopped by the Temple of Tapout on Friday to test fit some wheels on the car. Nothing new to report as far as the build but it won't be complete enough to be at Optima but it will be in the Turbonetics booth @ SEMA.
Shotgon shell bumper bolts
Ready for the Lexan windows.
-J
1 - 20 of 65 Posts
