I guess you could; some Ford 460 cranks are offset ground quite a bit to build 513's.
The crank will get weak if you turn it a great amount. The best way to describe what happens is if look at a crankshaft from the top and imagine each journal is disk. Now look at the way each of those disks overlap each other. Normally each rod journal overlaps the main by about half. That stiffens the crank. A good example of this is 400SBC mains are .200 bigger than the 350; and the stroke is .270 longer than a 350. That keeps the ratio of journal overlap about the same.
I used to work for a machine shop; the owner would take cranks that had spun bearings that eaten away the upper loaded side of the rod journals. He would offset grind the crank undersize until the journal was usable. It would move the centerline of the throw outward slightly increasing the stroke. Maybe .020 to .030 to slightly increase the stroke of a 400 by a few inches. The reason he did it was 400 cranks were had to come by and expensive.
The size of bearings available limit how much you can take off using stock rods. I think it also decreases the load area of the bearing. The bearing speed decreases; but from what I remeber it weakens the bearing.
350...Mains-2.45"-Rods-2.10
400...Mains-2.65"-rods-2.10"
350 = 4.000" x 3.48"
400 = 4.125" x 3.75"
