I'm thinking about pulling out the XE284 cam out of my 402 in my Chevelle and replacing it with a flat tappet solid cam.
Looking at Comp's selections I'm debating on a few:
XS268S 1600-6000 rpm band, .553/.568 lift, 230/236 dur @ .050
XS274S 2000-6400 rpm band, .568/.578 lift, 236/242 dur @ .050
But then again I'm also interested in Lunati....and being that the Voo Doo cam is the hot ticket right now, I'm curious as to if the Voo Doo line offers a flat tappet solid for big blocks?
What other brand of cams offer a solid flat tappet cam for big blocks?
What I'm working with is a 402 with a .030 bore, 290 oval ports with 2.06/1.72 valves, stock deck height with (I think) a .039 gasket, .180 dome Speed Pro pistons, 1.7 rockers, RPM intake with 750 Holley, TH350 with 3000 stall, 4.10's out the back pushing a 3620 lb car (with a 185 lb driver
) I do have power brakes as well as 1.75 primary headers thru a 2.5 inch exaust. And I may degear the car down to a 3.73 later on....still deciding on that one.
I'm going to guess the XS268S would be the best cam but what about the XS274S? Would either have enough vacuum for the brakes?
I'd also like to know what type of Lunati solid cams would work?
My car is street and strip use.
Also what kind of power gains are to be had going from a hydraulic to a solid lifter cam?
