Hey!!
I am NOT getting any traction from between 0 to 30 MPH!! No matter when I nail the throttle, in the stated MPH, it will blister the tires (new 235/60/15's) going sideways in both directions! I don't want "slapper" bars because they are limited to just stopping the rearend from tilting too much upwards! I am looking to either build or buy (if necessary) the best traction setup for a 73'!!
It's running a 455 with 10.75 to 1 comp. from a 70' Buick with an HEI conversion and 400 TH..........Rear Gears 3:73.......10 bolt, 8.5" spool and limited slip..............weighs between 2850 and 2900 Lbs. and so far I can figure the weight ratio 60F/40R (I will definitely need to change THAT!!!) I'm hoping someone else with a similar setup will have already been thru this and save me the aggrivation of a "hit and miss" hissy fit!!!
I'm glad I belong to a car club where I have unlimited resources (degrees of technical experience) but, most of these guys are FORD and Mopar freaks and have alot of suggestions (NONE of which are related to my problem) on what to do with it!!! On my 73', the only part of my frame work that doesn't fill the length is from the subframe forward! I WILL have problems with this, I'm sure, because the torque is at least 510 lb. ft. plus and I believe this motor has approx. 400 + HP. In a full weight Skylark it was running high 12's @ 100 - 103 MPH in the 1/4 with 3:08's. Can't wait to see how it does in the Nova!!! I will post timeslips as I work to get this (ahem) "driver" finished!!
Thanks in advance for ANY and ALL replies!!
BTW: I know it's NOT pure Chevy, but what can I say? GM invested well?!!! LOL!!!!
jammon73
jammon73
