I'm having trouble lining up taillight hole with qtr panel it appears the tailpanel is too tall could the leaf springs be pushing trunk floor up any suggestions would be appreciated.
Keith,I thought it may have been the picture.hey Joe the picture exagerates the flange
I not a body expert, but i dont know away to corect that. if you pull it down, you lose the line on your deck lid. if you leave it, you have that uneveness unless you apply body filler to it to reshape it.
i think the sail portion has enough metal to cut and make it fit properly. if you dont need the sail panel, you can always cut it down and make everything else match up.when I was fitting the qtr panel up to the door,trunk and tailpanel it was too high at the sail panel. If I lined every thing else up the tailpanel at the light would be off
