1 - 8 of 8 Posts
hello everyone, is there something that i'm not doing right? if i click on chat at the top all it does is open new window with a little red square up in the left hand corner. do I need to download something. thanks Joe
It sounds like you might have java turned off, or a firewall that prevents it from running. A high security setting will also stop it from loading.
You can check your settings by clicking on the top toobar of your browser: Tools > Internet Options > Privacy.
Al
hello Al, went to privacy, and my secuity is set low, and turned my popup blocker off, an still all it does is open a window with small square box up in left hand corner with red x in it. how do I check my java? thanks Joe
java should be in the same area, but under the "Advanced" button. there should be a check box.
I'm not sure what else could do what you mention. No firewall that blocks it? Some companies block it as well.
Al
1 - 8 of 8 Posts
