MSD digital 6/Blaster SS coil, change to HVC blaster 2 coil..
Im concidering this swap after learning my Blaster SS coil is pretty weak. The swap would be from this... http://www.msdignition.com/coil_blaster_6_8207.htm
to this..
http://www.msdignition.com/coil_blaster_18_8253.htm
Would this be a good purchase? I havent been happy with my plug burn from my Digital 6 and Blaster SS coil and ive allways seemed to have a slight popping and sometimes a hesitation on top end when im racing even though my plugs arent showing a lean condition. Im really concidering this after it was recommended. Anyone have any ideas or comments? What coil do you guys run with your Digital 6's? Are you happy with your setup? Thanks...
Re: MSD digital 6/Blaster SS coil, change to HVC blaster 2 coil..
Fuel issues sound like electrical problems and vice versa. Are you sure your Digital 6 box is acting up? (you can Ohm the transformer called a coil to see if it is still good). I would send it back for a check-up before I would buy more parts I might not need. I have the 7AL-3 set up and I melt my plugs with the current it generates (lethal amperage if you get hit by the spark so you have to be Verrry Kar-Full to Quote old Elmer Fudd).
I Read This Post A While Ago And Heard The Same Problem From Someone This Week, So I Looked In The Msd 2007 Catalog And They Say To Run It With The Hvc , I Have Not Finished My New Race Car But Looks Like I Will Be Changing The Coil Before It Runs. I Will Be At The World Finals And Will Ask The Msd Teck Rep About The Rec Coil , And Repost
