Lowering Blocks
2688 Views 2 Replies 3 Participants Last post by  lightninglar
Anyone found lower blocks that actually work correcty for a 67? With the screwball spring pad setup it looks like I am going to have to make something.
Hey Mike, here's a link I found @ steves it has some good info.
http://progress.theyellowduck.com/index.html
i looked at that link also, and was wondering if i had the poly spring pad in the right postion. i put both poly spring bushings on top and bottom of the spring with the lowering block on top of that, then into the perch. i also just drilled out the holes to 1/2 inch. looked simple enough, but i also added new multi leafs at the same time. i love the look...
