I need alittle help.My engine is running like crap and I can't dial in the edelbrock carb.Here's the situation.Lately my car has been rollarcoasting at idle.I used to have just breathers and the car ran pretty good.I switched over to a pcv setup and since then the motor has been running alittle rough.I tried messing with the carb to no avail.Today I plugged up the vacuum line running to the pcv,turned both ajustment screws all the way down and opened up both 3 full turns counter clock wise(From what I understand this is factory setup...not sure though???).Doing this the car is still running like crap...still rollercoasting???Anyone have any idea what is going on??Is it a vacuum leak?How do I trouble shhot for vacuum leaks besides starter fluid around the base of the carb?Can you engine/edelbrock guru's walk me thru this?Where's paul when you neen him???This is really starting to bug me!!!1 more question....om my edelbrock there are 2 cables hooked up...the top is the throttle...what is the bottom one?How is that supposed to be set up?I pull on it and about 1 inch of cable slack comes out.Is this normal?Thanks for the help guys.
Ps .....its a eddy 1405 manual choke.bm
