1 - 16 of 16 Posts
· Administrator
Kelly you can get one from our site sponser, link in the upper right corner. 68 - 72 (maybe all the way to 74) with Powerglide, th350 and 4 speed use the same cross member. It shouldn't be to hard to find one, TKO conversions using the kits came with new crossmembers. In the future you will need to put the for sale/wanted ads in the classifieds, it is free and easy.
That should be an easy part to find at any junkyard. any of the 68-74 Novas as well as the 67-69 Camaros used that crossmember and I believe the early Omegas, Apollos, and Venturas used it as well. It's probably A 10-15 dollar item at the local treasure hunters paradise.....
Tommy
I was recently at A yard at the Alabama/Mississippi Line that had 5 or 6 3rd gen Novas and A couple of 1st gen Camaros out in the mix and A friend called me last week about A yard close by that he walked for some parts that had almost A dozen 3rd gens
. We still have A few around here. I bought all the seat belts out of A blue four door 68 not long ago for 25 bucks. The ony thing messing us up around here is that mean ol mobile car crusher thingy that I see from time to time.
Tommy
Is your car a BB car? The only real difference between the SB crossmember and the BB crossmember is that the BB one is offset towards the passenger side slightly...you can just redrill the rear tranny mount bolts holes in the crossmember and that will allow the SB version to work with a BB car...if ya get what I mean
Discussion Starter · #11 ·
It seems that I would have to drill all the holes to slide the crossmember towards the passenger side? I'm not oposed to drill the small block one, my biggest concern is the mesurement to move it...?
No that is not quite right...all you need to do is redrill or elongate(sp?) the holes in the crossmember for the actual tranny mount...then you can offset the tranny mount itself towards the passenger side....the only thing offset on the factory BB crossmember is the tranny mount NOT the crossmember itself...Kapish:)
IF you car has BB frame mounts then with the motor mounted and sitting in the chassis straight it should be offset towards the passenger side of of the car the with the tranny bolted to the motor BUT not bolted the tranny mount it too should be offset towards the passenger side of the car...where ever the tranny wants to hit the cross member will be roughly where you want to drill it...it should be self explainitory when you see the parts together where you will want to drill it...
good luck :)
1 - 16 of 16 Posts
