1 - 11 of 11 Posts
I have a 72 nova with stock front and rear suspension only thing that it has is comp engineening shock front and rear . i have 275/50/15 tires on back 410 gears built small block with 550- 575 hp want to make it hook up. it will spin all 3 gears on the street and frist 2 at the track.
basketcase said:
Sticky tires are a must.
When I went to the track a couple of years ago in my malibu, on street tires, I smoked them to the 330'.
Then you could do cal tracs, slide-a-links or slapper bars.
Good luck
I made my own slapper bars and put them NEXT to the leaf spring. They slap on a piece of steel that I welded to the floor and not the spring. It give me the advantage of using different lengths - short ones for violent launches and longer ones for softer. A good set of externally adjustable shocks like the QA-1s are a must to control the launch.
· Administrator
Those slappers next to the springs are a good idea. It saves a lot of clearance issues and looks great. That would have saved me a set of Mickey Thompsons when my 'under springs' bar twisted and gouged out the tire.
Simple, yet elegant. Thanks for sharing.
Al
1 - 11 of 11 Posts
