Bicycle Bicycle frame Tire Bicycle tire Bicycle handlebar
so my fuel is getting too hot in the line and causing me ta stall out when just driving down the street? I recently added the glass filter just ta see and it doesn’t bubble until it gets up ta temp at like 190 degrees? I’ve just replaced the fuel pump, the thermostat and the fan sensor, I also added a heat shield under the carb and not sure what todo next?! Any suggestions or Help? Thank you
What kind of tank & fuel system are you running? Stock or aftermarket tank? Is the tank of gas cap vented? carb type & CFM? Fuel PSI? What motor set up? What motor manifold & carb set up?. 1 last thought. Your rubber lines are they possibly collapsing the e85 does a job on the regular rubber hoses.
lf you don't answer i can't help
