1 - 7 of 7 Posts
Discussion Starter #1
Hey guys. I was seeing if I could get ideas from you all about what could be wrong with my Nova. Its a 73 SS 350 automatic. A couple of weeks ago I replaced all the upper and lower control arms with brand new tubular ones. Bushing and all were included. I also replaced the springs and shocks. After driving it a few times I have noticed a slight clunk when I press the brakes after putting the car into gear. It only does it when i change from forward to reverse. No other noises otherwise. I was thinking maybe the sway bar link could be causing it, but the bushings looks ok. Could they be loose or something? Let me know what you all think. Thanks!
Discussion Starter #2 (Edited)
Oh yeah, i forgot to add. The new ball joints were included with the control arms, and pre-mounted. The only thing i didnt replace were the drum brakes and spindles, but the clunking didnt start until a few days after the install. I may go try and retorque everything since it didnt start making this noise until a couple days ago. Thanks
My guess is the front A-arm bushings are shot and the cross shaft is moving back and forth inside the sleeves of the bushings as you apply the brakes.
Discussion Starter #6
Figured it out...must not have stuffed enough grease in the A-arm fittings. All the mounting bolts were tight. They seem to be good now that i added some more grease. Thanks for the help.
1 - 7 of 7 Posts
