1 - 9 of 9 Posts
Hey all, I’m looking for assistance to ID an engine and trans from a friends parts collection who passed away.
any help is appreciated. I’m just not sure on what I’m seeing.
Engine reads:
Casting 3791362
8:45AM first shift casting
Date C256 - March 25th, 1966
Rear markings
H-21
S194
Front markings
174
362
G25
Transmission
Muncie M-21?
Date code: P0917 - Muncie Plant assembled on September 17th 1966
Main case casting number: 3885010
Tail housing casting number: 3857584
Side cover casting number: 3884685
27 spline output shaft
10 spline input shaft
Large bearing (64-74)
27 tooth counter shaft gear
VIN number stamp? 6S1050L0 (The 2nd to last number looks like a 1 but is different than the first 1)
Thanks for any assistance.
John
Automotive tire Wood Rectangle Artifact Font
Automotive tire Font Motor vehicle Wood Circle
Yah agreed Carl, I would like to know but the block is the same no matter which is desired to build. It certainly won't end up back in the original car. I was hoping the trans info would help. Still agood block and motor combo. Hopefully someone can use it. Thanks for you help.
1 - 9 of 9 Posts
