1 - 10 of 10 Posts
Discussion Starter #1
That is the size of tires my car came with. I need to buy new tires and I could option to E70-14, (I believe that =195/70R14. Can I do a 205/70R14 without it rubbing against my car while going through speeds bumps, potholes or turning?
Discussion Starter #3
I have that paged bookmarked and I have looked it over, which is why I know my current "wide" option size is the 195/70-14. What does "60 Series" and "80 Series mean? Are those the corresponding decades? Can I use a 205/70-14?
the 60/80 series is the relationship of the sidewall height to the tread width. The larger the number the taller the tire.
I recently switched to a smaller front tire. I wanted less tread width but the same height. Old tire was a 235R60/15, the new tire is 215R65/15. Same height, not as wide.
Aspect ratio explained.
my 76 nova came with E-78/14 and i put 205/78-14s on with they fit and look nice no rubbing they are the about the same height,width and ride height is a little better.the 205/70-14 would work as well.
Discussion Starter #8
Thanks, for the info.
Side note. 205/70R14
205= width of the tread in millimeters
70= percentage of tread width the side wall is tall. ie: 70% of 205 millimeters is your sidewall height.
14= rim size.
...and yes, 205/70's will fit fine, but as mentioned, converting to 15's opens up a lot of possibilities for tire sizes.
1 - 10 of 10 Posts
