The XE line is a more aggressive grind and will actually launch the tappet over the nose in a controlled valve float. That control off course is dependant upon how well you set up your valve train's geometry and the quality of the springs and the spring's installation on the head (shimmed for similar open pressure that live within the coil bind parameters).
I recommend the Magnum as a good grind for the street (I also like to look at the marine grinds with similar numbers because they are designed to live at WOT for hours to days at time without risking a failure).
I say all of this while I have an XE roller grind in my 406. I have been racing for decades, and I am familiar with the concept of preventive maintenance; that considers valve springs to be a consumable product. If you do not wish to follow my lead and trash valve springs and titanium retainers on a regular schedule then I would stick with the Magnum.
