Orig 350 car but not an SS and the throttle cable is too long. It has an edb. intake and holley carb and wen I got the car it wouldn't even go 1/2 throttle. I had a leftover holley throttle and kickdown bracket I used to replace what was on there but still had 3/4" of slop in the cable. Fixed that at the gas pedel by shortening the cable.
Now the problem is the casing from the firewall is too long, as well a strand or 2 of the cable itself has broken. If this hadn't happened I could just put the other throttle bracket back and shorten the cable at the pedel some more.
For a replacement was there more than one cable available? It would really be nice to buy one that fits correct but with the aftermarket carb and intake I realize that may not happen...
Comments? What did you do? I'm sure this is a common problem...
TIA,
TIA,
