1 - 8 of 8 Posts
Greetings, I am about to rebuild the front end on my '71. What is the best brand of coil spring to use or which do I stay away from?
Has anyone tried Lesjöfors? They are $66.00 a pair which makes me nervous.
I've also noticed that there is a different application for the 4 door (mine is a 2 door). Are they stiffer, different dimension altogether or what?
My car is original and I plan to keep it at stock height. Not looking to lower it any. I have read in other forums that Napa springs are not producing what they promise. Some suppliers are not asking for specifics such as A/C or engine size.
I've seen other posts on this topic but they have some age on them. Any help would be greatly appreciated.
I have used lasjofors in my 1962 6 cylinder conversion to 327 I have had not problem with them even with beating it on the track I wanted stock hight that’s what I got I pay twice that for one from Napa no miles on them not what I want for stance and rough ride also broke rear Napa at a launch that was my reason to change 2 years still going strong that not my opinion that 2 years proof 4 door a stiffer ride they’re meant more for four-door luxury driving There what I have in my 63 nova wagon witch is what I’ll put in 62 if I ever change nice for power tour rides
Discussion Starter · #6 ·
Thanks. I went with Western Chasis. They're suppossed to be here in a couple of days.
I also learned something about control arm bushings. Make sure to get Polygraphite not Polyurethane. If getting them from Energy Suspension be sure that the part number has a "G" at the end. The other tend to squeak a lot.
No squeak with the black, the red needs lubricating to prevent squeaking, they provide the lube in their kits.
Go to Eaton Detroit Spring for American made springs they will treat you right
1 - 8 of 8 Posts
