Hey Welcome to ya
i can help you on this... after the old leafs are removed, install the front eye bushings in the new leafs, question, do you have std rubber bushings or polys ? if they're polys make sure you use dielectric grease and lubricate the bushings to prevent squeaking. after the bushings are installed install the front of the leaf in the perch. be very carefull when you install the front eye "Cup" bolt... make sure the cup is seated in the hole prior to tightening. don't cinch down/torque any bolts until the car is done and it's back on the ground. OK, now the front eye cup is installed, slide the differential onto the leafs and center it over the leaf spring center bolt. instal the leaf shock plates and loosly tighten the U bolts (U bolts recommended, not the factory Tee-bolts) the spring rubber pads you can dispose of, they'll not fit the factory mono perch with multi-leafs. install the shock plates, u bolts etc and center the bolt of leaf in the center hole on bottom of plate. jack up differential and with new bushings in the back of leafs, install the shackles remembering to again, lubricate all wear areas of bushings if polys.
reconnect e brake cable, fluid lines etc. i'd also recommend replacing the upper rear brake hose while you're under there, possibly changing diff gear oil while you're at it.
once everything is hung, bled and attached etc lower car on the ground and torque/tighten all bolts.
i think that'll do it, i don't think i forgot anything
good luck to ya,
JR
