I'm looking to stiffen up my 66 nova a little. Who makes the best frame connectors for these cars ??? Bolt in or weld in, it doesnt bother me either way. Thanks......
bob
Best bet is a full cage as the little duce will get "twistty" if you put a lot of power through it. It is also nose heavy even with the SBC (seriously traction limited with the BBC over the nose).
i have a 67 whitch i think is the same,anyways i used the compition eng.bolt in conecters .i welded them in the front and bolted them in the back .they also move the rear springs in 3 inches that alow the use of a 8 inch wheel with 51/2 back spacing.on your other question ,im using stock mono leaf ,comp eng tracktion bars and the key is the comp eng anti roll bar.it might be even better with the slide a links but that 325 dallars will be later on sometimes .good luck getting in the 12s with these cars is pretty easy.
