I looked over the old threads on this and excellent pictures but still a little unclear what works.
I have a 454 with no A/C no power brakes and manual steering. The drivers side header is a frog hair from rubbing the steering box but no issues. The engine is centered and appears to have older tall mounts .To keep the same geometry exactly the same what engine and motor mount combo do I need for new parts and everthing still stays the same?
The previous builder seemed to have it right as the only clearance issue is the steering box, but it does clear. When pulling the engine this spring I would like to make sure I have the mounts and newer header issue already figured.
