I'm looking for any information or pictures for a 1965 Nova SS with a 283 220 HP Intake Manifold and Carb. I'm very intrested in the showing of the automatic choke hookup. I've been told that the 4 barrel Carb uses a small Choke Heat Pipe that runs for the Exhaust Manifold over the top of the valve cover on the passenger side to the Carb. Looks like this pipe is approx 3/8 In. in size. This same Manifold and Carb setup I beleve was used on all 1965 Chevrolet's with the 220 Hp option L77 engine. The casting number on the Intake is 3866922, I don't know the Rochester Carb number so any info on this would be a great help, also car is factory AC equipped. Thanks
· Administrator
You are right about the heat tube. It was also covered with an asbestos sleeve to keep the risk of burns down. This tube was also used on the 2 bbl. The 4 bbl carb used on some was a WCFB, I think this one was made by Carter, there was another produced by Rochester. It was 4 small barrels of equal size. I have one in a box somewhere. I will try to find it and post a picture.
