This is one of the rarest nove engine options ever offered only 643 were built in '65 with the 327ci
cast # 3790721
date code K74 = november 7th 1964 (for the 65 model year)
date stamp pad F1212ZA = flint assembly dec 12th
Comes with matching dated 461 double hump heads and a 4577 std/std crank
block has been cleaned magged bore is 4.030 needs light hone/bore to be ready for .040 pistons will clean up easy
as there is very minimal wear and no taper.
comes with original main caps
has upside down '721' on both block sides
deck surface is excellent with orig ZA stamping denoted 327-4 speed 4bbl
great deal if you want to restore one of the rare factory 327 4 speed cars from '65
check pics i will upload a few more pics later.
engine block & heads & crank will be crated and shipped on a metal engine cradle
via freight anywhere in the usa or canada for fixed cost of $250
see pics shipped from sumas washington pick up in person available.
cast # 3790721
