bellhousing alignment (tech article) - Nova Tech
Performance High Performance!
Old Mar 12th, 08, 03:57 PM
Guest
Posts: n/a
Default bellhousing alignment (tech article)
Hey NovaGuys & NovaChicks,
while looking for offset alignment dowels for my scattershield i found this interesting article that i thought would help some of you... take a look
http://www.camaros.org/bellhousings.shtml
i've added it to my JollyRodder site in the Link-Library for those of you who use it...
be Good !!!
Johnny
Old Mar 12th, 08, 04:43 PM
stock z/28 stock z/28 is offline
stock z/28 has a positive reputation
Default Re: bellhousing alignment (tech article)
Hi John,
Thats cool article. The guy that builds the tools and the bellhousings in right here in Lafayette. Very sharp guy.
Jeff
Old Mar 12th, 08, 07:57 PM
67 Nova Boy 67 Nova Boy is offline
67 Nova Boy has a positive reputation
Thanks for the link John!! I have never done that but will do when I yank the 302 out to freshen up!!
How did your's turn out?
Dave #3
67 Nova Boy
Old Mar 12th, 08, 08:05 PM
Guest
Posts: n/a
it didn't
the best Dave and i could get after numerous attempts was .007, and that's not good enough. it has to be within .005 (recommended for any Manual trans application, not just Tremec)
the dowels i used are an inferior product and that's probably the issue. they weren't offset the amount they claimed... so i'm waiting to get a better/higher quality set on order...
here's what i'm ordering http://www.robbmcperformance.com/products/dowels.html
Old Mar 12th, 08, 08:25 PM
bbdeuce bbdeuce is offline
bbdeuce has a positive reputation
I have one of those Browell bellhousing tools. Its go or no go. Of course it did'nt go. So , I got some of the lakewood adjustable dowels that you turn with a wrench and got it so the bushing would slide in and then locked it down. Should be fine. I'm installing a tremec so I wanted it perfect. I might be interested in renting the tool out if anyone is interested.
Old Mar 12th, 08, 08:30 PM
Guest
Posts: n/a
i used the drive in Lakewood dowels
they were supposed to be .014 units but didn't measure out that way... i looked locally for the dowels you're referring to but my local speed shop didn't carry them. they'd have to order which put costs over the ones i linked above...
i'd have been interested in renting the tool you mentioned but i'm already set up with a dial indicator... i know it's probably harder to do this way but it's here and didn't cost me anything...
Old Mar 12th, 08, 10:11 PM
Personally, I would think the indicator would be more accurate, than the tool, as far as concentricity to the crank center line, but that's just me.
Another issue that is not often talked about on the bellhousing is the surface where the trans bolts not being parallel with the flange that bolts to the block.
I have started (a couple years ago) grinding the trans mounting surface on a flywheel grinder so its accurate. Some are way off.
You can check that with an indicator off the crank, if you set the indicator up to sweep off of the mounting surface instead of the brg surface.
Old Mar 12th, 08, 10:16 PM
Guest
Posts: n/a
Jeff i forget if it was you or Philip that mentioned that to me a few days ago... i have to clean all the paint from the mounting surfaces and check the face as you're now suggesting (again maybe) uneven(?) paint takes up space...
sure is a lot different from when i was a young man... just slam the bell & tranny together and run it. but that's ok, the quality of parts have improved so i guess it's worth the extra effort to ensure longevity
Old Mar 12th, 08, 10:32 PM
John we talked about buffing the paint, but I dont think I mentioned checking the face of the bellhousing.
I actually think the older Lakewoods (pre MR Gasket) were more accurate than the later ones.
Old Mar 12th, 08, 10:35 PM
Guest
Posts: n/a
OK, then it was you well i took it that if the paint was uneven enough to cause the surface to be off then i thought it was meant it should be checked... so that's the plan. i'm hoping all this doesn't turn into a nightmare but i'm going to do it all. i mean, why not. if ya have the tools, USE 'EM
Old Mar 12th, 08, 11:14 PM
We talked about the paint removal and checking the face too. Jeez you getting old timers again An on the dowels you have, you get what you pay for
Old Mar 13th, 08, 10:39 AM
David_H David_H is offline
ANTIGODERATOR!
David_H has a positive reputation
Ummm yah John you were telling me I think monday how you and philip talked about cleaning the paint off remember I couldn't remember if I cleaned my paint off and said ohwell if I ever pull the housing I will have to check it but atleast I know its dialed in the way it is
shheeeesh and just in case you don't remember me my name is David I am your good looking friend in Acton I have a 67 nova that we are doing body work to do you need a picture???
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
67 coupe 355 tko600 posi "MY MISTRESS" build link
Stupid questions make more sense than stupid mistakes...
occasionally you have to just point and laugh.
  #13
Old Mar 13th, 08, 10:42 AM
Guest
Posts: n/a
no, it's too early ta have the daylights scared outta me by lookin' at yer mug
that much i DO remember !!!
Dialing in a bellhousing 1quik69 Engine 4 Feb 5th, 08 12:09 PM
Front end alignment problems chevnovaowner Brakes & Suspension 8 Jan 11th, 08 09:21 PM
