Post Your Tremec Swap Questions for 1962 - 72 Nova - Page 2 - Nova Tech
Driveline Transmissions & Differentials
  #16
Old Feb 9th, 09, 01:01 PM
Guest
Posts: n/a
Default Re: Post Your Tremec Swap Questions for 1962 - 72
i have a collection of pictures comparing the TKO / T5 / Muncie differences... side by side pics and quite a few installation shots
http://rides.webshots.com/album/507270287QnWxoa
  #17
Old Feb 9th, 09, 03:17 PM
chevyIIheavy chevyIIheavy is offline
chevyIIheavy has a positive reputation
Originally Posted by Philip View Post
My McLeod bell housing has the dual pattern and will fit a starter on either side.
i like these units to bad they dont fit all novas i have a 63 and the guys from mcleod said i would have to modify my trans tunnel he told me to just use the lakewood sfi bellhousing
  #18
Old Feb 9th, 09, 03:25 PM
Guest
Posts: n/a
here's the Lakewood unit i used: http://store.summitracing.com/partde...5&autoview=sku
it needed a slight amount of clearancing for the headers...
i'd recommend trying to go hydraulic if possible with an aftermarket clip. Heidt's centers the engine (1") and that's going to make the z bar too long and will need to be sectioned/shortened. also to clear the inner fender because of the z bar lever a 4" x 4" hole is needed in the inner fender for z bar lever to swing.
here's a Lakewood housing for the T5 tranny that David H used on his '67 with a hydraulic set up that worked great with his Heidt's clip: http://store.summitracing.com/partde...5&autoview=sku
hope i helped
JR
  #19
Old Feb 12th, 09, 03:07 PM
KeislerJeff KeislerJeff is offline
Jeff
KeislerJeff has a positive reputation
All Novas will need floor tunnel mods but dont let it scare you, the results are totally worth it!
  #20
Old Feb 12th, 09, 03:45 PM
Guest
Posts: n/a
Originally Posted by KeislerJeff View Post
All Novas will need floor tunnel mods but dont it scare you, the results are totally worth it!
i'd say X2 but i think it'd be a higher value than that... absolutely the BEST component on/in my car. now i'm not going to bag on the TKO for racing, but if the car was a dedicated 1/4 mile track car, i'd go with an automatic... but OH Man, on the street, Freeway cruising... i don't think the TKO can be beat... unless you go with a T56 6 speed
  #21
Old Feb 12th, 09, 09:25 PM
Originally Posted by Gloryhound View Post
When is someone going to design a multi bolt explosion proof bell housing that fits Chevy, Buick, Olds, and Pontiac engines? I want to go with the 5 speed eventually, but I don't want to have to get two bell housings as my car will probably start its street life with a crate 350 while I beat the snot out of it I will be building my 501 cid Pontiac engine. Also when will the 6 speed get a redesigned mount that will mount on Pontiac engines without the use of adapters?
Part number WE-8650
  #22
Old Feb 20th, 09, 11:13 AM
droptop63 droptop63 is offline
droptop63 has a positive reputation
Hello, I have a 63 nova with a 383, about 500HP, has 350 auto with shift kit, 373 gears, It gets the job done, I miss shifting, I want to switch to a 5 speed or 6 speed, I know the 6 speed will cost more, but what are the pros and cons verses 5sp or 6sp, thanks
  #23
Old Feb 20th, 09, 04:52 PM
Sprinter Sprinter is offline
Sprinter has a positive reputation
Can you throw shifts with these rial type trans the same as a munice and a Hurst shifter?I mean basicly stomp the clutch and yank the shifter when speed shifting. All the rial types I've driven were not very friendly that way.
  #24
Old Feb 27th, 09, 11:37 AM
Keisler Keisler is offline
Keisler has a positive reputation
With a LOT of fab work, you can make the T56 work. The 6-speed has 2 overdrives to keep you in the powerband at highway speeds of 55mph and up. The shift quality of the T56 is better than the good quality of the TKO.
Our PerfectFit 5-speed is the only Tremec kit that puts the shifter EXACTLY in the factory location. You can run a console or not, use the factory carpet, boot, ring, etc.
We will have a '67 Chevy II coming to the shop next week for a TKO PerfectFit kit and hydraulic clutch kit.
You guys interested in some pics and video??
  #25
Old Feb 27th, 09, 01:47 PM
Guest
Posts: n/a
do we have to supply our own popcorn ?
OF COURSE we want a write up & video !!!
  #26
Old Feb 27th, 09, 08:51 PM
Thats Cool!!
  #27
Old Mar 5th, 09, 04:29 PM
Thumbs up Re: Post Your Tremec Swap Questions for 1962 - 72
OK, the car is here at our shop. It will be coming up on deck shortly.
Video and pics to follow... Stay Tuned!
  #28
Old Mar 5th, 09, 09:14 PM
ttt
  #29
Old Mar 9th, 09, 06:11 PM
Hi Tom,
Yes, you can definitely do that up to about 6500RPM. Above that, the shift speed will drop off, as the transmission was not designed for that. It doesn't mean it can't or won't shift at the higher rpm.
  #30
Old Mar 14th, 09, 09:14 PM
OK, thanks for the info.
Tags
keisler, kiesler, t56, tko, tremec
bucket seats 72 nova car-man602 Interiors 3 Nov 23rd, 08 08:21 PM
Need external dimensions of '72 Nova catwoman! Body Shop 7 Mar 22nd, 08 10:45 AM
'72 Nova Promo? mathewkozak New Member Introductions 3 Oct 27th, 07 05:08 PM
72 Nova Overdrive Trans Swap 72Rally Driveline 4 Jun 1st, 07 09:36 PM
72 Nova Rear Assembly Swap 72Rally Driveline 2 May 29th, 07 08:42 AM
