Mom's grocery getter 406 - Page 4 - Nova Tech
Performance High Performance!
  #46
Old Nov 8th, 19, 11:59 PM
Default Re: Mom's grocery getter 406
I haven't heard of any problems with a Blue print block. There are three levels of strength with a Dart block. I use Big M's or Sportsman blocks for most builds as I won't be pushing it as hard as I would in a blown alcohol engine. So 750 horse is fine for any four bolt BBC (even a stock 454 block as far as strength goes).
I like big bore blocks so a 540 or a 555 is a perfect street engine. To me a stroked big block is a 632 (4.75 inch stroke, but even that engine will rev as high as a hydraulic roller can take it. You just couldn't keep tires on the car!)
Chris will build your rear clip with any axle you want. You just tell him where you want the spring perches for a leaf sprung car, or the mounting points for a four link and he will weld it up.
I order the Moser Dana 60 with four link brackets hanging loose as I don't don't know how far apart to weld them until I get the tires I want under the car and the rear frame rails welded in place. The axle tubes on the Moser rear are so thick that almost any one can weld on them without warping the tubes.
  #47
Old Nov 9th, 19, 10:59 AM
ramportin1 ramportin1 is offline
ramportin1 has a positive reputation
Thanks! This is all really helpful to me and reassuring. So do you know if that M60 can be ordered narrowed to any length? With my mini tubs and all that work i want to ensure I maximize my results by narrowing the housing to the best size for best tire size and fitment. Now with a M60 I'll have to redecide on the CA sportsman ladder bar/coil over set up or the Detroit speed quadralink setup. I planned in the ladder bar because of it being less complex of a install and tuning, but I do have some people I could get help from who have done 4 links before, and buy the Jerry bickel 4 link wizard.
Sent from my SM-G975U using Tapatalk
  #48
Old Nov 9th, 19, 11:01 AM
Originally Posted by Aukai View Post
The 406 is a collaboration between Mike Lewis racing engines, and Mark Jones (Vortecpro)
I was able to buy a Nice 67 Nova roller, and needed a motor quick, so my wife would not throw a hissy fit if I get the car running as soon as possible. Mike Lewis built my 572 for the Chevelle, but when I got in touch with him he stated his lead time was way out. My next choice was Mark Jones, who has a super reputation also. I was able to work out a deal with both of them, Mike for parts, and Mark for his expertise in assembling, and his attention to details. We made a game plan, and Mike did the parts selection, and ordered all of the parts, with Mark asking for certain vendors for pistons rings, etc. For a street car this effort has turned out VERY well, considering I can only use a Victor Jr. for hood clearance. Mark took care of porting, and getting the most out of it, and it sings. Mark Witener (JMarkaudio) did the billet 1000HP carb. Video at the bottom.
This is the parts list if anyone is interested. Mark answered all of my questions, kept me updated when ever I called, super to deal with. Mike, and Mark excellent job, and results. I am extremely happy, the hair was even standing up on my arms. This is on 91 octane.
DART SHP 31161211 350 / 4.125
1067 AFR 23 SBC Cylinder Head 227cc Race Ready Heads, standard exhaust, 75cc
MAHLE 930200755
406 4.155 442 12.6 11.7 10.9 SBC125155F05
COMPSTAR CRANK SAJ-113-CS
MOLNAR STROKER RODS
BEARINGS
MOROSO 21017
MOROSO 24170-
MELLING 10553
BULLET STEP NOSE BILLET CAST GEAR CAM
R285/415B 285 255 177 .4150 .009 CRA 1.6/1.6
R289/390B 289 259 178 .3900 .012 CRA
108-109+4-5
ISKY 372RHEZMax
CROWER SHAFT ROCKERS 74141F
ROLLMASTER TIMING SET LATE CS1090
CAM THRUST PLATE & BOLT SET
CAM BEARINGS
ATI 917781 W/BILLET ADJUSTABLE POINTER
ALUMINUM FT CVR & BOLTS
VLV CVRS & BOLTS
GASKETS
PAN, SEALS, HEAD, INTAKE, VLV CVRS, FT CVR, WATER & FUEL
HEAD BOLT, PAN STUDS, FUEL PUMP BLOCKOFF PLATE, STAINLESS CORE PLUGS
https://youtu.be/odst_HpVYHg
Second time listening to this haha sounds awesome
  #49
Old Nov 9th, 19, 03:26 PM
Aukai Aukai is offline
Aukai has a positive reputation
Kinda hard to hear though. Blueprint does not torque plate hone as part of their normal procedure. you would need to check on that information though, I feel it is an important step. My 572 is a Dart Big M short deck 4.375 stroke, pump gas, and is for the 70 Chevelle. We tried 4 intakes, and 3 cams. It now has a sheet metal manifold and 2, 2000 cfm throttle bodies. This video is only one of the combinations.
https://youtu.be/TTN8nCaUw44
  #50
Old Nov 9th, 19, 03:39 PM
Very cool, that must be a fun chevelle!
  #51
Old Nov 9th, 19, 03:42 PM
I'm hoping, but it's in paint shop prison right now, hasn't been driven yet.
  #52
Old Nov 9th, 19, 08:45 PM
O dang! The anticipation would be killing me
  #53
Old Nov 10th, 19, 01:30 AM
It's been an 8 year build....so far.
  #54
Old Nov 25th, 19, 01:36 AM
I changed out some black, for polished AN fittings to break up some of the black theme.
  #55
Old Nov 25th, 19, 11:58 AM
Lookin good..
  #56
Old Nov 25th, 19, 02:25 PM
I do like the polished fitting swap, it breaks up the black nicely
leftcoast carl's 406 dyno update 2 black ragtops Engine 9 Mar 27th, 08 12:12 PM
leftcoast carl's 406.dyno day results. 2 black ragtops Engine 8 Mar 16th, 08 01:30 PM
Mom told me not to talk to strangers ArtBee New Member Introductions 10 Jan 10th, 08 05:38 PM
406 stopped running Steelrat Performance 3 Sep 2nd, 07 03:07 AM
