How can I improve my cars horsepower and sound? - Page 3 - Nova Tech
  #31
Old Mar 26th, 20, 06:25 PM
Elvis Elvis is offline
Elvis has a positive reputation
Send a message via Yahoo to Elvis
Default Re: How can I improve my cars horsepower and sound
Yeah, start with a 355 built to '70 LT1 specs...tickle it with a 150HP whiff of nitrous...then you're ready for Street Outlaws.
Elvis
P.S. Weren't we talkin' about inline sixes? Whatever happened with that kid?
  #32
Old Mar 26th, 20, 07:06 PM
Zspoiler Zspoiler is offline
Michael and or
Zspoiler has a positive reputation
You just use the normal hot rod tricks on it And with to days tech you can even go to fuel injection .I have even seen people split the exhuast .There should be some books out there from SA and HP books that may help.
  #33
Old Mar 27th, 20, 08:45 AM
Hmmm, probably because this thread drifted off the subject and he didn't get his question answered and gave up.
  #34
Old Mar 27th, 20, 03:12 PM
???...I thought my response addressed his question quite thoroughly.
Elvis
  #35
Old Mar 27th, 20, 08:43 PM
Elvis
It did but then it drifted off.
  #36
Old Mar 28th, 20, 01:28 PM
Talking Re: How can I improve my cars horsepower and sound
Yous guys!
  #37
Old Apr 18th, 20, 01:33 PM
Rets Rets is offline
Rets has a positive reputation
Default
Ok I wanna tubocharge the in-line six any suggestions on what I should go with? And replaced the muffler now it has a growl and I like it thank you Elvis.
  #38
Old Apr 18th, 20, 02:23 PM
Take the muffler off all together. The turbo will be your muffler
Install twin turbo(s) off of two Plymouth or Dodge Neons (K-cars). You have 4.0 liters of engine to feed and the Neon has a turbocharged 2.0 liter four cylinder engine.
Use everything in terms of plumbing as you can hit (waste gates, inter cooler tubes intercoolers, oil feed lines, everything that isn't a four cylinder engine.
You will have to fabricate your own custom tubular headers feeding the two turbos with three cylinders each powering a single turbo. This limits lag time to spool up and will power your car with four to six psi of boost. You will also need to go to port injection EFI with two longer duty cycle injectors on the two middle ports (that feed two cylinders) and two shorter injector cycles (fewer pounds of fuel per hour) on the end ports.
If you ever get it running don't forget the race gas as your going to be adding a lot of dynamic compression. Just keep track of expenses and compare it to a 305 SBC out of a high mile Chevy in comparison to cost. Both will have the same power level. If you want more power out of a turbo charged six you need SBC Siamesed heads welded together to make a six cylinder in-line head a new cam, and forged pistons with deep dishes to keep the dynamic compression pressure down to be able to burn gasoline: or you could burn straight methanol like an F1 race car.
The only down side to a Chevy straight six is it will crack the block between the #1 cylinder head bolt and the water outlet bolt every time it is pushed hard. So you will get good at engine building after a while. I got to where I could pull my burnt up VW engine out of my Karmen-Giha and rebuild it on my lunch hour I did it so often. Six is more cumbersome and a lot heavier (I could yank the mostly magnesium VW engine with one hand and carry it to the work bench)
  #39
Old May 7th, 20, 08:15 PM
"... replaced the muffler now it has a growl and I like it thank you Elvis."
You're welcome.
Not much of a turbo fan, so I'll bow out on that subject.
Instead, I will just stick by what I originally posted.
