Dead no juice - Nova Tech
Old Jul 24th, 19, 03:04 PM
nova70ss nova70ss is offline
Lou
nova70ss has a positive reputation
Default Dead no juice
I have a 1970 Nova ss, I went to start it and I have no electrical. Battery was checked and is okay. What can be the cause?
Old Jul 24th, 19, 03:57 PM
Brian
Default Re: Dead no juice
Grounds, shorts in wiring
71 Nova
SBC 427
238/256 Girly Cam
6.88 1/8th @ 100.00mph
Old Jul 24th, 19, 04:26 PM
Art
Ignition switch.
62 Nova wagon
75 Nova Custom
75 Nova Base
Old Jul 24th, 19, 05:58 PM
Welcome to the Team Lou!
Or a blown fusible link; which is an open circuit (the opposite of a short).
Old Jul 25th, 19, 02:44 PM
Aukai Aukai is offline
Aukai has a positive reputation
I can't remember exactly, but there may be a common ground on the radiator support near the horn relays?.? Dave would be a master at this one if it's there.
Old Jul 25th, 19, 07:24 PM
On older cars (earlier than 1969) that would be the main power feed to the car going through the horn relay/mechanical points for the voltage regulator (depending upon the alternator type).
There are two fusible links in the wiring: one by the battery that handles all power in the car, so when it opens nothing works, and a second across the top of the firewall that feeds the cabin and the front under hood wire loom.
Fusible links are short small diameter wires located next to sheet metal, and away from other flammable things, that burns open if there is a short in the wiring. You find it by looking for the burnt wrapping and blistered appearance. It will bend easily because it is empty (the wire has vaporized inside).
Old Jul 25th, 19, 11:48 PM
Art
Fusible link wire is also wrapped in a special high temp insulation that will not melt and catch fire before the wire melts and breaks contact.
62 Nova wagon
75 Nova Custom
75 Nova Base
Old Jul 28th, 19, 10:41 PM
Lou
Many thanks for all your replies (You guys are the best!!!!), I dis-connected the battery cables (battery is a side poster) and burnished both ends that bolt into battery and solved the problem. Since i'm the original owner
Old Jul 29th, 19, 12:10 AM
Art
It's amazing what clean connections will do, LOL..
62 Nova wagon
75 Nova Custom
75 Nova Base
Old Jul 29th, 19, 04:21 AM
Good job
