Mom's grocery getter 406 - Page 2 - Nova Tech
Performance High Performance!
  #16
Old Aug 7th, 19, 03:54 AM
Aukai Aukai is offline
Aukai has a positive reputation
Default Re: Mom's grocery getter 406
The hyd release bearing that came with the car is a no go, so while my wife was at work I used the glass dining table for measuring parts. Bellhousing depth, candle stick shoulder height, also checked bellhousing to finger height on the block,and got a Mcleod 1308 bearing ordered. Checked starter to ring gear, I would have to take material off of the aluminum starter pad to make it better, so it will stay there. If I did not have an engine leveler it would have been a bad day, there was a lot of finagling to get the SBC to sit on the pads. Then I have the "wrong" block mounts. I wanted to use the Poly mounts, but the driver side has a flange that hit the rack shaft. I'll lift it up again tomorrow, and put the Moroso mounts that came with the car on. The car has been under cover with the hood closed, and the car cover on, the rack shaft looks pretty bad in the flash. Something else to do I guess...Dialing in the bell also, along with setting up the clutch for hat height, finger height, base, and counter weight.
  #17
Old Aug 8th, 19, 02:37 AM
Today's adventure with Moroso solid mounts, is that it's not lining up. These came with the car, I do not know the application. The other mount has the bolt 1/2 way though, the passenger is not even close. I'm thinking taller mounts?
  #18
Old Aug 8th, 19, 09:43 AM
Call em up, they may have given the wrong ones, never know???.
  #19
Old Aug 8th, 19, 01:12 PM
My opinion also:
https://www.moroso.com/pub/media/pdf...MountChart.pdf
  #20
Old Aug 8th, 19, 04:49 PM
Thank you both, when I get home from work Sat, I'll get after it again. Thanks for the chart, I was looking for it last night.
  #21
Old Aug 11th, 19, 05:02 AM
Narrowed, and lengthened for close to stock capacity.
  #22
Old Aug 11th, 19, 09:47 AM
Nice..
  #23
Old Aug 11th, 19, 10:00 AM
Beats a fuel cell all the way.
  #24
Old Aug 11th, 19, 03:28 PM
Thank you Art. Dave I agree, my 70 Chevelle is only notched, not back halved, so I could stay away from a cell. Just my preference too.
  #25
Old Aug 12th, 19, 03:20 AM
The 68 Nova lists 2 block mounts for the SBC short for the 327, longer for the 350. The SHP block is probably modeled after the 350, and would have shorter mounting points on the block. I just need to space the mounts with the Moroso spacers when they get here tomorrow. Fingers crossed this fixes the 67.....
  #26
Old Aug 12th, 19, 09:37 AM
Hopefully it'll be a quick and easy fix..
  #27
Old Aug 12th, 19, 05:48 PM
brian oneil brian oneil is offline
Senior Tech Team *
brian oneil has a positive reputation
The SHP block is modeled after the 350 LT1 engine block. My 427 SB has the SHP block. I am using stock frame mounts for a SBC for a 71.
71 Nova
SBC 427
238/256 Girly Cam
6.88 1/8th @ 100.00mph
  #28
Old Aug 13th, 19, 02:55 AM
Thank you, it sucks waiting for the mail to arrive.
  #29
Old Aug 24th, 19, 10:20 PM
Wasn't real easy, but in, and out a couple of times I figured out the mount height. The red glow is the awning color....
  #30
Old Nov 7th, 19, 05:11 PM
Just keeping the story line going for the updates. These are on the checkoff list, battery is mounted, radiator, valve cover vent tank with plumbing, billet fuel pump, with Straub push rod, plumbing to the carb, and plug wires with looms. I'm feeling like there is too much black going on, I may change the AN hose fittings for the valve covers, and tank fittings to SS to break it up a bit. I dunno.....
leftcoast carl's 406 dyno update 2 black ragtops Engine 9 Mar 27th, 08 12:12 PM
leftcoast carl's 406.dyno day results. 2 black ragtops Engine 8 Mar 16th, 08 01:30 PM
Mom told me not to talk to strangers ArtBee New Member Introductions 10 Jan 10th, 08 05:38 PM
406 stopped running Steelrat Performance 3 Sep 2nd, 07 03:07 AM
