Power Steering... - Nova Tech
Old Oct 31st, 07, 05:16 AM
novadave496 novadave496 is offline
novadave496 has a positive reputation
Default Power Steering...
1970 Nova 454BBC bored and stroked to 496... Car has no power steering and I would like to add it... I haven't found any kits of that sort... so any ideas on what i'm looking for to start my project?
Old Oct 31st, 07, 12:02 PM
Lead Slacker
Default Re: Power Steering...
Power steering pump, Power steering gear w/correct pitman arm, good set of hoses (I believe BBC specific) and the BBC brackets.
I have an extra pump and gear with pitman, but the BBC specific parts I do not have. I would trade the power parts for the mechanical gear.
USA "One Nation Under God."
I've gone full size!
1963 Impala SS Convertible
Old Oct 31st, 07, 05:18 PM
Power steering pump and the hoses are specific to the big block because of where the low pressure return enters the tank to clear the heads an block. A BBC pump will work on a SBC but not the other way around. Brackets are of course also different because the mounting point holes do not line up from one block to the other. You have two pumps to chose from fast ratio or "normal". Fast ratio has fewer turns lock to lock (three instead of five if I recall correctly).
Source them off of a Camaro which more frequently than a Nova shipped with Power Steering (1968-74 first gen Camaro and 1975-79 use the second generation Camaro). Also in there will be a point in time when they went from the old style ASE fittings to Metric with an O-ring; that I can not recall, but I think it was in 1975.
Finally: on the Camaro board are a couple of articles written about setting up the Camaro for road racing (Trans/Am-Can/Am SCCA stuff) as there are about three different pitman arms with different tie rods to make it handle better, which are also applicable to the appropriate Nova body as we use the same front end (depending upon the year).
Old Nov 3rd, 07, 07:52 AM
Wow, Thanks guys for all the help i'm starting to look around for the pieces I need. The shop I work at is almost done with the engine and power steering and trans are my next projects... Thanks for the help..
Power Steering slomo_01 Nova Tech 1 Jul 20th, 07 11:37 PM
power brakes jim454 Brakes & Suspension 1 Apr 7th, 07 02:40 PM
steering stop adjustment?? darreny Brakes & Suspension 1 Apr 5th, 07 03:49 PM
Need help with steering wheel installation kentsu Nova Tech 0 Mar 22nd, 07 09:12 PM
steering column? darreny Troubleshooting 14 Jan 31st, 07 04:38 PM
