starting problems and running problems - Nova Tech
Old Apr 1st, 11, 06:45 PM
'78 beast '78 beast is offline
joseph
'78 beast has a positive reputation
Default starting problems and running problems
i have a 350 with a 600 holley and when i try to start it, its either really hard to start or it back fires out the carb. it doesnt matter if the distributor is as far advanced or retarded it stills back fires but if i keep cranking it and play with the gas i can get it to run. i dont know whats wrong or where to start looking. does anyone have any ideas??
Old Apr 1st, 11, 06:54 PM
ss67nova ss67nova is offline
Rich
ss67nova has a positive reputation
Default Re: starting problems and running problems
My have missed the timing by a tooth or so and be sure to recheck the firing order
Old Apr 1st, 11, 07:30 PM
Blown73 Blown73 is offline
Senior Tech Team *
Jeff Hayes
Blown73 has a positive reputation
You could be 180 out...
You can never have enough horsepower or ammunition
https://www.novas.net/forums/showthread.php?t=19521
Old Apr 1st, 11, 11:44 PM
Joesph what was the last repair or modification you made? Did it run well ever or did you buy it this way? Need a little more info to make a good diagnosis.
64 Nova
77 Nova, 406, TKO 600, 3.73 8.5" 10 bolt SOLD
72 Chevelle Concours wagon
Old Apr 2nd, 11, 01:02 AM
JAYARTER JAYARTER is offline
Senior Tech Team *
JAY
JAYARTER has a positive reputation
That is a big 10-4.....
the more info you can share makes it easier to help you....year, make model, carb, dist type ect and we do love pictures J
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
http://photobucket.com/photobucketcomJayBj
66 SS Chevyll
67 Elcamino
68 Malibu 2 dr
69 Camaro Conv
Old Apr 2nd, 11, 07:36 AM
poorman72 poorman72 is offline
Randy
poorman72 has a positive reputation
Joseph, I would check the choke to make sure it is working right. It sounds as if you have a lean condition at start up. Hope this helps.
Old Apr 2nd, 11, 03:53 PM
joseph
it ran perfectly when it was in originally and i took it out to put a higher hp engine in it. i had it down to a short block and put it back together the way it was not changing anything. now that i want to add more hp to my other engine i put this one back in. i just cant figure out why it takes for ever to start and back fires out of the carb, i have checked the firing order a couple times. its a gen 1 350 standard stroke and bore, has a pretty big cam and a holley 600 carb, delco plugs.
Old Apr 2nd, 11, 03:55 PM
joseph
will an engine even run 180 off
NO.
Look inside the distributor cap for carbon tracking. You may just have a cracked cap.
64 Nova
Old Apr 2nd, 11, 04:22 PM
joseph
Originally Posted by Philip View Post
NO.
no its a brand new dist and cap
Old Apr 2nd, 11, 10:59 PM
So, they can be damaged before you get them. It is just a thin cardboard box wrapped around it. If you have the old cap put it on and see if it makes a difference.
64 Nova
Old Apr 3rd, 11, 09:48 AM
Senior Tech Team *
JAY
Greetings from Arizona
I'd redo dist....take out #1 spark plug and crank up to #1 firing position and make sure its set correctly, is it HEI? or Stock Dist? What did you change and were they new parts? Could the timing chain be installed correctly? Is it a slow crank? If dist is correct, you might do compresion test! Hopefully something we suggest helps. Jay
66 SS Chevyll
67 Elcamino
68 Malibu 2 dr
69 Camaro Conv
  #13
Old Apr 3rd, 11, 03:40 PM
It will run with up to 4 spark plug wires installed wrong. Do not even ask me how I know that
64 Nova
  #14
Old Apr 3rd, 11, 03:48 PM
winterhawk winterhawk is offline
James
winterhawk has a positive reputation
I had a simaler problem with my 64 Nova that has a 670 Holley Street Avenger on it and the key was to find the proper choke setting. Loosen the three screws on the side of the choke assembly and by process of elimination,try the different notched positions to see where the carb wants to perform the best when you start it up.
  #15
Old Apr 3rd, 11, 09:52 PM
joseph
i figured it out. thanks everyone for your input. the distributor was advanced one tooth. i took the hold down bolt off picked it up retarded it one tooth on the cam and it fired right up. now i just have to adjust some rockers and its good to go.
two problems mopar_moose Troubleshooting 4 Feb 17th, 10 09:47 AM
Problems JeffersonC Electrical & Wiring 6 May 24th, 09 02:36 PM
starting problems?? HELP!! 73nova Nova Tech 9 Aug 19th, 08 11:46 AM
problems for me gfercaks33 Nova Tech 10 Feb 3rd, 08 07:23 PM
64 nova 4 dr. Starting problems!!! raysanchez2003 Troubleshooting 5 Mar 11th, 07 05:02 PM
