350/396 engine swap - Nova Tech
Performance High Performance!
Old May 14th, 19, 11:18 PM
smf396 smf396 is offline
smf396 has a positive reputation
Default 350/396 engine swap
Hello everyone, i have a couple questions, and seek your knowlege for help.I just purchased a 1972 nova, and i am going to swap the 350 for a 396 now here is my questions ,do i need to change motor mounts? and do they make adapter brackets to be able to use the alt. and power steering pump off the 350 thanks for any help.
Old May 15th, 19, 08:49 AM
Default Re: 350/396 engine swap
Welcome to Team Nova!
Old May 15th, 19, 10:28 AM
thank you
Old May 15th, 19, 10:34 AM
Welcome to the Team!
Yes a 496 will require BBC frame stands and interlocking motor mounts (a BBC will pull standard vulcanized motor mounts apart with engine torque). Check on Team Camaro for a wealth of information on buying the correct parts (you will have to check dimensions of the parts you buy for being correct as there are a lot of poorly reproduced parts out in the market).
I mention a 496 not as a typo but because a 396 is useless. You want a 454 with a quarter inch stroker kit (rotating assembly) because a BBC is very inefficient on pump gas. It was designed as a very high compression racing engine (13.6:1), and cutting the compression ratio in half to run on pump gas (454 truck engine has 7.8:1 compression) kills it's power potential. You have to make up for the handicap of dragging around another 220 pounds of cast iron over the front axle with building a bigger displacement big block.
A 406 SBC will just about double the power of a 396 with out the added cast iron handicap, so you don't want a 396 just the decal. A 454 looks just like a 402/396 from the outside and few can tell the difference even at a car show with the hood up. I ran a 582 with 402 decals, but I never raised the hood. No one believed the decal, but they never knew what I had until after it was too late.
I sent you a list of all of the parts you will need in the form of a car magazine article talking about a BBC engine swap. I suggest you print it out as I'm not going to be around much longer to send you a another copy.
Old May 15th, 19, 01:22 PM
ive allready built the 396 and im not short on power or torque lol
350 to 396 roger72 Nova Tech 15 Jun 11th, 19 02:57 PM
1970 Nova SS 396 700r swap slickrick124 New Member Introductions 3 Oct 11th, 13 07:01 AM
396/375 or 396/350 1969SSBigBlock Engine 4 Mar 25th, 11 12:15 AM
350 to a 454 engine swap youngster 72 Engine 7 Aug 26th, 09 11:10 AM
1969 Correct 396/375HP SS engine Factor Nova Tech 2 Jul 27th, 08 01:20 PM
