Steering Column Interchange - Nova Tech
Old Aug 4th, 09, 02:16 PM
69X11SS 69X11SS is offline
Jim
69X11SS has a positive reputation
Default Steering Column Interchange
OK, I need help from the Nova guru's. The Hollander manual (online version) shows that the onlny steering column interchange for a 71 Nova is with another Nova or a Pontiac Ventura. Is there something about a 71 that I am missing or is the database wrong?
There is a fine line between hobby and obsession and I think I crossed it!!
69 Camaro SS 350 5 Speed
69 Corvette Convertable 350 4 Speed
71 Nova 350 4 Speed
94 Z28 6 Speed
99 Corvette convertable 6 Speed
www.cardomain.com/ride/719562
Old Aug 4th, 09, 08:47 PM
ovrdrive ovrdrive is offline
Dan
ovrdrive has a positive reputation
Default Re: Steering Column Interchange
Not to my knowledge... I owned 7 of those 71's and the 70-74 parts were interchangeable. There might be some "under dash" wiring differences but, the steering column should be a direct bolt in. It's been a while but I am sure that someone with a 3rd gen could help out.
1966 Chevy II 2-door
355 390hp
200-4R 22-2500 stall
4.10 posi
http://www.youtube.com/user/dty1996
Old Aug 4th, 09, 10:23 PM
Youngladd Youngladd is offline
Youngladd has a positive reputation
I have to go with Dan on this one. I put a 69 column in my 72 with no problems. I think 69-74 are interchangeable as 68 still had the key on the dash. I was told that there is differences with the trim piece under the column, but don't quote me on that, for I have had NO personal experience with it.
Old Aug 5th, 09, 12:25 AM
The 75 - 79 Nova column, the 70 - 81 Camaro column and the 69 - 72 Chevelle columns will also bolt in BUT the shaft needs changed. On a non tilt this is real easy, just slide one out and the other in. With a tilt it is a major disassembly.
Old Aug 5th, 09, 09:43 AM
Jim
Thanks for the responses. I didn't think there was a mechanical or measurement issue. Once upon a time I had a 70 big block SS 4 speed car and I knew that the column in it is the same as the column in the wifes 69 Camaro. There must be an issue with the Hollander online edition.
PHILLIP An addtional thanks for the info on the later years. That will broaden my search and make it easier to find what I am looking for.
71 Nova 350 4 Speed
94 Z28 6 Speed
Old Aug 14th, 09, 03:09 PM
Jim
Bingo, I found a floor shift column out of a 69 Camaro in excellent condition. It is exactly what I was looking for and it is only 15 miles from home and $65.00. I pick it up next week when the owner gets back from vacation.
71 Nova 350 4 Speed
94 Z28 6 Speed
Old Sep 9th, 09, 01:47 AM
Tekno62 Tekno62 is offline
Don
Tekno62 has a positive reputation
Was wondering what shaft are you talking about. I found a 78 trans am with tilt and was hoping I could replace my stock column with it.
Old Sep 9th, 09, 08:52 PM
The shaft would need to come from a tilt column and involve a complete disassembley to change. On a non tilt column the shaft will just slip in and out by removing a snap ring and the turn signal switch.
The column will work if you can have some one remove the steering coupler mount plate from your stock column and weld it on to the end of the tilt column shaft in the correct position.
Old Sep 17th, 09, 09:43 AM
Jim
Man did I get lucky with the floor shift steering column that I bought. Diassembled, cleaned and painted the housing it looks perfect. I cleaned out the bearings and repacked them. The only thing that I had to replace is the key warning buzzer switch which was broken of course. I figured that it would be. It was broken in the wifes 69 Camaro and my 69 Corvette. Everthing else is good. Putting in new lock cylinder that matches all the locks on the car. One key fits all.
71 Nova 350 4 Speed
94 Z28 6 Speed
Old Mar 18th, 15, 09:41 AM
1971NovaBM 1971NovaBM is offline
Steve
1971NovaBM has a positive reputation
I have a 71 nova, when i bought it the shifter was converted to a floor shifter the guy left the the old column in. It worked but i have done some overhualing over time and now when i connect the battery the dash lights up the cooling fan turns on the fuel pump starts with no key in the ignition. When this is all happens i put the key in, turn forward just a hair and everything turns off. I turn just a little bit more and the motor wants to turnover. Im new with this stuff im trying to figure out if it truly is the column and it needs to be replaced/repaired or its just a straight out wiring issue.
Old Mar 18th, 15, 09:50 AM
Art
Welcome to the Team Steve!
http://s18.photobucket.com/user/GoFa...%20Nova?page=1
62 Nova wagon
63 Nova wagon
75 Nova Custom
Old Mar 18th, 15, 10:03 AM
Sounds like a worn out ignition lock. The lock is available as a separate part from the key but since it sounds like yours is worn out I would buy a replacement for both. But this is done over the internet without seeing anything, which isn't how you fix a car's mechanical problem.
Steering column interchange Philip Nova Tech 0 May 16th, 09 11:45 AM
steering column 1970novass Interiors 3 May 2nd, 08 05:50 PM
Steering column for 72 ? ARE1971355 Nova Tech 1 Feb 19th, 08 02:16 AM
1973 Nova Steering Column ssupernova Nova Tech 3 Sep 19th, 07 05:50 PM
Steering column take apart? Jesses Nova Tech 2 Jul 9th, 07 10:03 PM
