S10 rear end with Disc brakes in 63 nova? - Nova Tech
Old Jul 31st, 09, 09:59 PM
cartoolrus cartoolrus is offline
Mike
cartoolrus has a positive reputation
Default S10 rear end with Disc brakes in 63 nova?
I talked to a couple of folk about putting a S10 rear end with Disc brakes in 63 nova. They recommended the 2WD donor vehicle because of the width (54.5" to wheel faces) vs 4WD (59" width). Anybody done this to their car? Any tips?
Old Jul 31st, 09, 10:57 PM
Default Re: S10 rear end with Disc brakes in 63 nova?
Welcome to Team Nova.
The S10 had a 7.5" ring gear and an 8.5" ring gear, if buying one get the 8.5" the other will not handle much torque. The 8.5" is very rare, it was used with the 4.3L with a manual transmission. Not all the Xtreme models had the 8.5" rear.
Old Aug 2nd, 09, 09:32 AM
Tuckin20s Tuckin20s is offline
Mike
Tuckin20s has a positive reputation
I've got the 2wd one with drum brakes.I used subframe connectors that stepped the spring in 2 ins. and left the rear hangers where they were.I went to Napa and found a fitting that was standard on one end and metric on the other to mate the brake lines.I've got 20x10s and they clear.
Cool Aint Never Cheap Or Easy
Link to my Nova pics
http://www.novas.net/forums/showthread.php?t=11996
IN GOD WE TRUST
Old Aug 2nd, 09, 10:05 AM
Mike is it a 7.5" or 8.5"? Sure looks good with those fat tires under it
Old Aug 2nd, 09, 10:08 AM
SHIFTY4 SHIFTY4 is offline
~the Sedan Man~
what size are the rear tires ?
also, your signature link doesn't work
also known as...
JohnnyRotten
the FLYER
Old Aug 2nd, 09, 10:17 AM
The sig link has the ..... in it which render it useless. If it was more complete I could have fixed it.
Old Aug 2nd, 09, 03:16 PM
Click here
Old Aug 3rd, 09, 05:40 PM
Mike
Thanks for the heads up on the link,I fixed it.The tires are 275-30 -20 Kumho.The rear is 7.5 w 410s that I've had in it for 2yrs with a 350/700r4 .If it breaks it's $100 at the pic a part lot.
IN GOD WE TRUST
Old Aug 4th, 09, 01:39 AM
Nwayne Nwayne is offline
Nwayne has a positive reputation
Did you move the leaf spring perches? What subframe connectors did you use?
Old Aug 4th, 09, 01:55 AM
Slammedsdyme01 Slammedsdyme01 is offline
Dustin
Slammedsdyme01 has a positive reputation
The s-10 7.5 rears will take a little pounding if they're done right. I was into s-10s for a while and helped put together an 01 s-10 which has a procharged ls swap for a friend. The truck runs in the high 9s and still has the factory 7.5 rear. We were searching for an 8.5 to build but they were only offered in certain trucks (most of them manual v6 models) and even the majority of those have a 7.5. Anyway we put a set of axels and a spool in the 7.5 and it has held great for the last few years.
Old Aug 4th, 09, 04:22 PM
greasemonkeychef greasemonkeychef is offline
Casey
greasemonkeychef has a positive reputation
I would be intrested in what sub frame connectors were used too! Is the wheel whell modified in anyway? That car looks good with all that meat under it
Tags
s10 disc brake rear end
1979 nova rear end question edsmith978 Driveline 10 Jan 16th, 09 11:02 PM
my 71 nova rear end? footbrake Nova Tech 1 Oct 5th, 08 11:41 PM
70 nova rear end upgrade??? fjas70 Driveline 9 May 13th, 08 06:01 PM
Nova Convertible TCI Front & Rear Kit 63 Convertible Guy Convertibles 4 Jan 27th, 07 06:13 PM
1970 nova rear end interchange quack44 Driveline 5 Oct 5th, 06 09:56 AM
