1966 - 1974 Bucket Seats, Tracks & Floor Mounts - Nova Tech
Interiors Upholstery & Soft Trim
Old May 24th, 09, 09:36 PM
71SS 71SS is offline
71SS has a positive reputation
Default 1966 - 1974 Bucket Seats, Tracks & Floor Mounts
It seems there are a lot of requests for correct buckets seats for Novas.
I did a little research a couple of years ago and got some info on the buckets seats from 1966 to 1974 Novas.
Since I can not put all the pictures into one post, I will divide this into three posts.
1. seats
2. tracks
3. mounts
1966 to 1974 Bucket Seats
  • This is a link to brochures on 1962 to 1979 Novas, there are several pictures of bucket seats for you to see the different patterns used over the years. http://www.classicnovas.net/brochure/index.htm
  • The following is what I think I know for sure at this time. I believe the bucket seat frame is the same for all 'A' body cars. The tracks, headrest and seat back locks will determine years.
    ”I didn't see it mentioned here, But the 66 and 67 was the only years that the back and bottom covers were metal. 68 they went to plastic. And I have a set of green 66's that the ribbon trim around the base covers was the interior color (aqua). Never saw that in the later years, they were all chrome”
66 buckets - no headrest, headrests were an option (info from DesertDeuce), backs do not lock.
67 buckets - no headrest, imagine since headrest were an option in ’66, probably same with ’67, backs lock with lock buttons on the side.
68 buckets - no headrest, Headrests were an option. Backs lock with buttons on side, the lock button is not in the same place as 67 and the backs are a little different due to the buttons and the way they connect on the back of the seat.
69 to 71 - headrest installed, lock buttons in the middle of the back of the seat back.
72 to 74 high back buckets
The only difference I've seen in the high backs are the button
locations and I can not tell which is which.
I think these are 74's
Old May 24th, 09, 09:37 PM
Default Re: 1966 - 1974 Bucket Seats, Tracks & Floor Mount
Tracks - probably the biggest problem for everyone is with the correct tracks.
66 & 67 tracks - same tracks, both are same height, the seat will sit level if sitting on the ground.
"I checked the measurements on the 66 buckets
length of tracks 15 1/2" tip to tip
Front height 2 1/8"
Rear height 1 1/2"
JR"
“Don't think this was posted but 66 tracks have open "TOES" where as 67 is closed. Another words... the front holes that bolt to the floor are open. As they can slide on the stud. 67 are closed in the front. You have to put the track OVER the stud to bolt the front track to the floor.
66 tracks... Passenger side I think. They are 14" 1/2 from center of mounting holes.
67 Nova Boy”
66 tracks
67 tracks
68 to 71 - same tracks, different heights, seat will lean towards the door side due to the inside tracks being higher.
"My car is a 68 with bucket seats the brackets were never removed so I hope these pictures will help everyone with questions on the 68-71 bucket seat tracks. The track with the lever measures 14 inches ctc and the inner track measures 14.5 inches ctc. 12 inches between them.
Measured the height for you. Inside track front measures 3.5 inches high the back measures 3 inches. Outside track the one with the handle front measures 3 inches and the back measures 2.5 inches. This is from the bottom of the mounting bracket to the top of the track hope this helps.
Jason 68 L78"
Here's my measurements
Here's the measurements for the height of each mount.
Measurements are from the brace the track bolts to the bottom of the track mount. pics show them upside down.
Inside track front mount 3-1/2"
Inside track back mount 2-3/4"
Outside track front mount 2-5/8"
Outside track rear mount 2-1/2
72 to 74 - tracks same height, seat will sit level.
I have no other info or pictures on tracks for these years.
Seat mounts
They are all welded into place on the floorboards and 72 and up are bolted as well on the outside mounts.
66 floor pan with mounts
68 mounts consist of four pads on floorboards for each seat.
68 Nova mounts were 4 pads on each side as shown in this pic from jason 68 L78
69 to 71 mounts, two pads on outside tracks and the middle mounts go over the trans hump with bolts on both sides.
72 to 74 almost identical to 69 to 71 with the exception of the bolt placement in the mount.
pic courtesy of 2slow72
This is a good diagram of placement of mounts supplied by NovaShopNet
http://www.novashop.net/info/console.htm
Old May 24th, 09, 09:39 PM
I want to thank others that have provided info for this thread.
onequiknova
JR
67 Nova Boy
Jason 68 L78
DesertDeuce
2slow72
If there are others, thank you and I apologize for not remembering.
Old May 24th, 09, 09:53 PM
Thanks for all your hard work Dan. This info should be a help to anyone replacing floors or converting to buckets. I will be transfering buckets from a 76 parts car to my 77. Mind if I post the photos here to document the 75 - 79 bucket seat info?
Old May 24th, 09, 10:02 PM
No problem, glad to have the info here. One thing I have found out about the later years, the mounts from a 75 and up are different than the 72 to 74.
Old May 25th, 09, 11:23 AM
SHIFTY4 SHIFTY4 is offline
~the Sedan Man~
i agree, excellent write up... here's a few more shots of a '66 floor pan, bucket seats and an automatic shifter hump.
click on image to view album
also known as...
JohnnyRotten
the FLYER
Old Jun 12th, 09, 05:44 PM
Dale51 Dale51 is offline
Dale
Dale51 has a positive reputation
I am new to Novas, but have been part of other forums on chevys. I just wanted to say thanks. This is the most indepth research on seats for my 66 Nova that I have seen as of yet. I appreciate being able to glean from someone who has already "done it." Thanks!
Now for the question. My 66 Nova post car needs front bucket seats. I don't care if it is original or not. I just left the upholstery shop and they told me my front seats were not worth the repair. They think they came out of an old camaro. So I am off to the junk yard to harvest front seats out of something so that the rod shop can re-upholster them. Can you advise me what to look for? I'm looking for comfort at my age (52).
Old Jul 15th, 09, 06:13 PM
choo choo ss choo choo ss is offline
Tom
choo choo ss has a positive reputation
I'm looking to buy a 66-67 auto shifter floor hump. Helpful info on the seats thx
Old Sep 10th, 09, 12:55 PM
75 - 79 bucket seat mounts.
To mount a newer style seat in my 77 I moved 3 of the studs to line up with the Firebird power seat track mount. The 2 outboard and the rear inboard. It was really easy to do.
Old Jan 5th, 10, 09:18 PM
woodnmetal woodnmetal is offline
john
woodnmetal has a positive reputation
71ss nice job!! is this all you have to do during the day? That's some prety intense research! Would you by any chance, have a picture or two on the original 4 speed hump for my 67..? I think the 66 67 pan you have shown is a auto hump. Am I correct?
I really have no idea what the floor pan is supposed to look like. Mine is all stripped out.
Old Feb 6th, 10, 08:20 PM
69dream 69dream is offline
ryan
69dream has a positive reputation
Hi everyone, need help with my project. I'm putting bucket seats in my 69 nova and it originally had bench seats. I bought the 4 piece bracket set from classic industries and I'm not sure exactly what bracket goes where on the floor pan and I'd like to be sure before I start welding. I'd appreciate any help I could get. Thanks!
  #13
Old Apr 26th, 11, 06:49 PM
Keith68 Keith68 is offline
Keith
Keith68 has a positive reputation
You were saying that 72-74 tracks are all the same, cause one of the restoration companies told me 72 was 1 year only and 73 and74 were the same. was 73 and 74 seats the same shape as 72? thanks for any advice you can give me.
  #14
Old Apr 26th, 11, 09:03 PM
It's been a couple of years since I did this research, so I looked back over my info. I never measured the tracks on these years but the reason I say they are the same as the mounts are the same. Maybe some folks with these years can measure theirs and post that info.
The buckets seats them selves are the same.
  #15
Old Apr 27th, 11, 01:42 PM
Keith
Thanks for the info, it was very helpful.
70 nova bucket seats yankee Nova Tech 14 Nov 11th, 09 11:51 AM
67 Nova bucket seats jumpiola Interiors 3 May 16th, 09 09:06 AM
bucket seats for 74 nova jerryt Interiors 6 Jan 5th, 09 11:11 AM
need pictures of 1972 nova bucket seats options ss72novatompetty Interiors 5 Nov 19th, 07 08:43 PM
bucket seat tracks owlhoot Interiors 0 Dec 22nd, 05 08:03 AM
© 2009 AutoForums
