Rear shock relocation - Nova Tech
Old Mar 1st, 09, 05:36 PM
Default Rear shock relocation
The rear disc brake set up I am using necessitated the drivers side shock be moved from its stock location. I had two options, move both shocks inboard and behind the axle or move the drivers side forward of the axle. Moving inboard was my first choice but that location interferes with the running of the exhaust over and behind the axle. So with only one option left the design process was started.
To move the lower mount I ordered spring plates for a 67 Camaro from Detroit Speed and Engineering. The 67 - 69 Camaro and 68 - 79 Nova share the same rear end design, but the 67 Camaro was the only model that had non staggered shocks. The 67 plates were just right for moving the lower mount forward of the axle.
This is a photo comparing the stock plates with the ones from DSE. Besides relocating the shock position they are a much heavier construction. I also made the switch from 1 u-bolt and 2 t-bolts per side to 2 u-bolts per side.
The upper mounting area wasn't going to be as easy. The stock mounting location isn't all that impressive as far the amount of metal the factory used to anchor the top of the shock. It is two pieces of thin sheetmetal and an 1/8" thick mount plate all welded together. I was using 1/4" x 2" steel strap for the bracket which is not quite twice as thick. The second factor was to modify the body as little as possible and it ended up only one 7/16" hole was going to be necessary.
I thought that using the existing mounting area for the main attaching point would eliminate the needed for major modifications to the body. This is the first design that was made from a cardboard template, it would have worked fine but I did not care for the way it hung below the contour of the sheetmetal, plus it would have required long bolts and spacers. I also realized it did not need the second plate originally part of the design.
A week passed as I thought there just has to be something better looking I could do to mount this shock. I realized with the tire on it wouldn't be visible but it just wasn't what I wanted. The first thing was to remove the extra plate that was intended to reinforce the area that shock bolted to and then to contour the bracket to match the shape of the body. There was also going to be some type of fastener to secure the forward end. This is what ended up being the best design for the needed strength and shape I was happy with.
It fit the body well and mounted the shock at the same angle and installed height as the passenger side.
A new hole location for the forward mounting point was marked and drilled to install a blind nut. The blind nut is a threaded insert that is installed like a rivet. It provides a threaded hole when there is no way to get a nut on the end of a bolt. This is the tool used and a photo of the installation.
The blind nut is on the left side of the photo and the stock mount area on the right.
The following photos are of the install of the shock to the bracket using the hardware supplied by QA1, the spacers used to position the bracket where it was needed and the install into the car.
It will be a few months before I can road test the car but I am confidant it will be fine.
Old Oct 14th, 09, 06:47 PM
jim454 jim454 is offline
jim
jim454 has a positive reputation
Send a message via Yahoo to jim454
Default Re: Rear shock relocation
Awesome set up,were those QA-1 shocks expensive?I would love that setup on my 76.Maybe you could tack weld the bolts to the back side of the plate then you wouldn't have to take the whole bracket out if you want to take the shocks off.Good job!!
Old Oct 21st, 09, 11:54 AM
Jim the shocks are around $140 each and can be rebuilt.
Old Aug 23rd, 10, 11:32 PM
Well the bracket need to be re-engineered. The added mounting hole was not in a reinforced body section. So all of the spacers were removed and the bracket bent to fit flush on the reinforced part of the body its entire length.
Old Nov 16th, 13, 02:39 PM
Bruce Compton Bruce Compton is offline
Bruce
Bruce Compton has a positive reputation
This is a very good thread and shows what I am looking at doing. I wonder if someone has the same kind of project about moving everything to the back of the axle and inboard with a crossmember.
rear axle shock plates soundman Brakes & Suspension 9 Dec 1st, 08 07:43 PM
4th generation shock relocation jim454 Brakes & Suspension 4 May 3rd, 08 07:45 PM
66 nova weld in upper rear shock mount richieO66nova Brakes & Suspension 2 Jan 26th, 08 10:40 AM
shock relocation jaquesy350 Brakes & Suspension 8 Dec 9th, 07 09:29 AM
Rear Shock Mount Ideas gasser1963 Brakes & Suspension 4 May 26th, 07 12:15 PM
