64 Chevy Nova Rear Wheels & Tires Question - Nova Tech
Wheels & Tires What fits what?
Old Feb 3rd, 09, 10:30 PM
Stevie T Stevie T is offline
Steve
Stevie T has a positive reputation
Default 64 Chevy Nova Rear Wheels & Tires Question
I have a 1964 Nova with a stock 10" rear and I just bought Cragar S/S 15" x 7" with Goodyear TA Radials 255/60SR15" and I want to know if they will fit using a 4 1/8" rear spacing?
Old Feb 3rd, 09, 11:56 PM
SHIFTY4 SHIFTY4 is offline
~the Sedan Man~
Default Re: 64 Chevy Nova Rear Wheels & Tires Question
my vote will be an unfortunate... no
but i guess you already bought them, so check it out and see.
here's a site that might help you, best bet is to always measure your wheel opening etc to check/confirm what'll fit.
http://www.2quicknovas.com/tirefit.html
also known as...
JohnnyRotten
the FLYER
Old Feb 4th, 09, 09:20 AM
63gasser 63gasser is offline
Jon
63gasser has a positive reputation
Those wheels "should fit" with a 235 tire.
Old Feb 4th, 09, 09:24 AM
Steve
so I take it that the 235 is not as wide as a 255? The car happens to be in the paint stage now and I can't check it out till it's finished but I had the opportunity to buy these tires and wheels and I jumped on them.
Old Feb 4th, 09, 10:49 AM
1slow64 1slow64 is offline
jeff
1slow64 has a positive reputation
Yes, you are correct.
Old Feb 4th, 09, 12:26 PM
~the Sedan Man~
the 4-1/8 back space with the 235 tire is going to be very close to hitting. i had a set of 235's with 4-3/8 back space wheels on my '64 and barely had room... all cars vary from one to the next, so again, you already bought them so try them out to see if they'll fit.
added note, if you have rear discs or plan on installing rear discs i can tell you for sure they won't fit due to the thickness of the rotor moving the wheel out. a 4-1/2 back space (minimum) will be needed.
also known as...
JohnnyRotten
the FLYER
Old Feb 4th, 09, 07:46 PM
chevyIIheavy chevyIIheavy is offline
jim nelson
chevyIIheavy has a positive reputation
i have 15x8 weld draglites with a 5'' b.s. but when i had leaf springs on the car i had to use a 1/2'' spacer i also had to massage the inner fender a little when i ran these with leaf springs.
Old Feb 5th, 09, 03:06 AM
jays64II jays64II is offline
Jay
even a 225/60/15 tire on a 7" wide rim with 4-1/4" backspace is tight on the back of a 62-65 car.
mazzoni_enterprises@yahoo.com
Old Feb 13th, 09, 09:10 PM
Steve
Good News! I ended up using 235/60 15" there is about 1/4" on each side that clears the inner fenders, oh and BTW I found out that the previous owner did in fact cut off the rear wheel well inner lip and did a very good job doing it! So all is well with my tire issues! Now to the next issue....
Old Feb 13th, 09, 09:16 PM
~the Sedan Man~
COOL... one thing to look at while you're under there, check to confirm the previous owner sealed the cut out area to prevent water/dirt debris etc... ya don't need it accumulating and possibly rusting out later, right ?
glad ya got hooked up
JR
Tags
rear tires wheels
1979 nova rear end question edsmith978 Driveline 10 Jan 17th, 09 12:02 AM
66 nova wheels and tires aj68z28 Wheels & Tires 3 Dec 13th, 08 12:59 PM
Help on rear seat for a 65 chevy 2 nova. jasonsjump Interiors 2 Apr 22nd, 08 02:14 PM
64 chevy II rear end info lemonice Performance 7 Dec 11th, 07 11:56 PM
70 Nova rear tires? TDWZ28 Wheels & Tires 6 May 23rd, 06 05:32 AM
