NPT to AN Conversion Chart - Nova Tech
Old Nov 29th, 08, 09:19 PM
Novanutcase Novanutcase is offline
John
Novanutcase has a positive reputation
Default NPT to AN Conversion Chart
Can someone post up a conversion chart between AN and NPT. I need to know what 1/16" NPT and 1/8" NPT would convert to for AN.
I think it would be handy if this conversion chart was stickied for everyone!(Hey John, Might be a good addition to Jollyrodder.com)
Thanks!
John
Old Nov 29th, 08, 10:23 PM
SHIFTY4 SHIFTY4 is offline
~the Sedan Man~
Default Re: NPT to AN Conversion Chart
Hey John, ya might take a look in the "Air, Fuel, Electrical etc etc etc" section at JollyRodder... i have numerous AN links... maybe there's one there that ya need
also known as...
JohnnyRotten
the FLYER
Old Nov 29th, 08, 10:29 PM
AN is tube size expressed in 1/16th's of an inch. An AN-8 is 8/16th's or a half inch line. AN-6 is 6/16th's ==>3/8th's line. NPT is national pipe thread which is tapered. Some AN fittings have a NPT on the other end. All AN (Army/Navy or mil spec standardized during WWII) fittings use a 37° taper to seal, which is not compatible with SAE compression fittings which use a 45° angle. Bear in mind only the tube size has the inside diameter of the AN fitting, not the fitting itself which is much more restrictive. Another problem is the hose was designed to be light weight (aviation quality) hydraulic lines and do not work with alcohol (the lining material is made of natural gum rubber) or gasahol.
AN fittings became popular back in the good old days when we were scrapping out tens of thousands ex-military air craft. Now that you actually have to buy this stuff new (at $16 to $27 a fitting) I much prefer to use a Bridgeport high yellow brass SAE (Society of Automotive Engineers) fittings as they are a lot cheaper and work just as well without the bling.
Sorry I couldn't help.
Old Nov 29th, 08, 10:32 PM
John
NOPE!! You both helped ALOT!
So Dave....going by what you say that would mean that a 1/16" NPT would be a -1AN and 1/8" NPT would be a -2AN?
*****EDIT***** John, I just found it on your site! What a knucklehead I am!
John
Old Nov 29th, 08, 10:42 PM
There isn't a direct correlation between NPT (National Pipe Thread) and the size of the tube. I have seen from an AN-12 to an AN-4 fitting screwed into a 3/8th pipe plug hole.
Smallest AN line I have seen is an AN 4==> 4/16th's or 1/4" ID tube. For 1/8th inch inside diameter line, even on an aircraft, a copper tube with compression fittings is still the best route (has to be supported or the metal will fatigue if not supported and break) Though most aviation tubing I saw that size was stainless steel on old war birds.
Old Nov 30th, 08, 05:57 PM
62nova406 62nova406 is offline
Joey
62nova406 has a positive reputation
as stated AN fittings have a 37* pitch on a straight thread to make a leak proof seal to the mating surface loosing the need for a thread sealant . national pipe thread locks as the threads fall short along the major diameter of the taper. they are not compatible but jegs has alot of adapters like 3/8 npt to 6 an etc. etc. 4.00 bucks each i think
" IMAGINE THAT "
62 nova 406 sbc
456 gears 5500 stall powerglide
6.80's in the 1/8 th
street driven
slide show http://s470.photobucket.com/albums/r...view=slideshow
vid http://www.youtube.com/watch?v=DoocV93k1Fg
Old Nov 30th, 08, 07:08 PM
The Big Al The Big Al is offline
AL
The Big Al has a positive reputation
Send a message via AIM to The Big Al
Pipe thread is designated by the inside dia. It is a tapered thread.
Car domain
http://www.cardomain.com/ride/2845547
“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
doing disk brake conversion on my 71 Nova - do I n Tekno62 Wheels & Tires 8 Oct 2nd, 08 01:16 PM
rear disc conversion fjas70 Brakes & Suspension 7 Sep 29th, 08 02:03 AM
Church Boys rack/pinion conversion 67 church Forum Classifieds 7 Sep 21st, 08 10:11 AM
brake conversion angler0808 Brakes & Suspension 4 Apr 18th, 08 07:59 PM
72 6cyl to 396 BB conversion titan396 Restoration Corner 10 Aug 19th, 06 12:14 PM
© 2009 AutoForums
