'69 Nova rear tire/rim backspacing? - Nova Tech
Wheels & Tires What fits what?
Old Oct 27th, 08, 10:36 AM
cw41 cw41 is offline
Chuck
cw41 has a positive reputation
Default '69 Nova rear tire/rim backspacing?
I would like to put 275-60-15's on the rear but unsure of the proper rim backspacing or to use 15x7 or 15x8. I'd rather not cut or roll the lip unless necessary. Thanks for any advice.
Chuck
Old Oct 27th, 08, 12:29 PM
SHIFTY4 SHIFTY4 is offline
~the Sedan Man~
Default Re: '69 Nova rear tire/rim backspacing?
Chuck, the 2QuickNova's tire fitment page lists numerous applications that might help. http://www.2quicknovas.com/6874.html the listings are supplied by the car owners, some have better descriptions than others but they state if they have rubbing issues, what backspacing they used, rolled or non rolled lips etc... may not be the encyclopedia of tire fitment sites but it's by far the best out there... read & look at the images... maybe it'll be of assistance to ya.
JR
also known as...
JohnnyRotten
the FLYER
Old Oct 27th, 08, 01:46 PM
brian oneil brian oneil is online now
Brian
I used many moons ago a 275-60 15 on a 15x7 rim with a 3.5" BS and i did not need to roll the wheel opening and I never had tire clearance issues.
71 Nova
SBC 427
238/256 Girly Cam
6.88 1/8th @ 100.00mph
Old Oct 28th, 08, 12:00 PM
The Big Al The Big Al is offline
AL
The Big Al has a positive reputation
Send a message via AIM to The Big Al
I have the very tire now.
been mounted on two different rims.
15x8 with a min of 5 inch backspace. (it will be close to the lip.
15x8 with 5.5 inch Back space is a perfect fit. This does limit wheel availability.
The wheels by Summit and Weld Racing will work.
Warning, the 15x8 5.5 BS wheel by Greg Weld, will not clear Disc brakes. (Greg Weld is different than Weld racing)
This is the same tire 275/60-15 Cooper Cobra Tires.
Al
Car domain
http://www.cardomain.com/ride/2845547
“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
Old Oct 28th, 08, 08:38 PM
rj67bu rj67bu is offline
rick
rj67bu has a positive reputation
hey big Al, i have the same tire and wheel bs 5.5 mine rub on the inner wheel well have you mini tubed it? i have a split mono with an 1.5" drop looks similar to your ride height, but can't turn left to save my life with out rubbing the pas. side driver side rubbs also not as bad I have a 1/4" clearance on the pas side and a little more on driver side. what shocks do you have, and do you have a sway bar?
Old Oct 28th, 08, 08:44 PM
AL
No mini tub
Your car been wrecked?
Your split link with that 1.5 drop is your problem!
I have had this combo on 4each, gen 3 Novas with no issue.
Al
Car domain
Old Oct 28th, 08, 09:20 PM
rick
as far as i know it hasnt, undernieth is pretty straight no wrinkles I just realized that i PM'd you once and you told me it was a tight fit. as far as rear end not being centered from listening to other people i assumed this was normal driver side is probably 3/16 and passenger is 1/4 so probably just the point i measured from. thanks for info Big Al
Old Nov 8th, 08, 03:19 PM
68chevyll 68chevyll is offline
68chevyll has a positive reputation
I can't fit 5.5" bs either. I run 4.5" bs
Old Nov 18th, 08, 09:03 PM
Thorpedo Thorpedo is offline
Phil
Thorpedo has a positive reputation
I've been to 2quicknovas site, and they have tried a variety of tire and wheel combos.
I thinking about running 225/70/15's on the front on 15x7 w/4"bs, and 255/60/15's on the rear on 15x8 w/4.5" bs. Any opinions on clearance issues?
BTW, http://www.miata.net/garage/tirecalc.html is a good, interactive tire calculator.
Old Nov 20th, 08, 08:44 PM
I run 255's with 4.5 bs. You'll be fine.
Old Nov 20th, 08, 11:43 PM
AL
Thats going to be close!
Al
Car domain
Old Nov 22nd, 08, 01:17 AM
Phil
Al, if you think the 15x8 with 4.5" bs is close, what would you recommend 15x7 with 4" bs?
  #13
Old Nov 22nd, 08, 02:26 AM
AL
15x8 rim with a 4.5 back space leaves 3.5'' to the front
15x7 rim with a 4 inch bs leaves a 3'' to the front.
moved in 1/2 inch, plus makes the tire have a smaller section width.
Do you think the section width of the tire is the same with the smaller rim?????
Car domain
  #14
Old Nov 22nd, 08, 07:54 AM
My rims are 7" with 4.5bs. Plenty of room. check my sig for pics.
  #15
Old Nov 24th, 08, 12:52 PM
Phil
Big Al, Thanks. That's a pretty comprehensive summary. I did come across a set of
15x7's with 4.25 bs, and that sounds like it should work fine. My next question is I'm running stock exhaust and tailpipes, it appears that the left TP extends into the wheelwell. Has anybody encountered clearance issues wuth the tailpipes?
'69 Nova
396 cid - 4spd - 4:11posi
70 nova rear end upgrade??? fjas70 Driveline 9 May 13th, 08 06:01 PM
69 Nova 2dr interior rear window trim cw41 Interiors 10 Dec 4th, 07 12:47 AM
Body Panel Fit - 69 Nova SS tim68rsss Body Shop 7 Aug 10th, 07 01:50 PM
69 nova big block 262jp Nova Tech 1 Oct 29th, 06 11:09 PM
is it possible to replace rear wheelhousing? 69 nova. 1969ssclone2B Restoration Corner 10 Oct 23rd, 05 10:52 PM
© 2009 AutoForums
