rustoleum vs. por-15 - Nova Tech
Bench Racing Stories, cruising & more
Old May 1st, 06, 10:43 AM
burningsquirrels burningsquirrels is offline
burningsquirrels has a positive reputation
Send a message via ICQ to burningsquirrels Send a message via AIM to burningsquirrels Send a message via Yahoo to burningsquirrels
Default rustoleum vs. por-15
hey guys...
so i'm running around here and holy crap por-15 sounds pretty expensive... i was thinking of just using some rustoleum stop-rust instead. is there a big difference?
i'm going to be using it around the rear window where some rust holes have formed along the bottom corners. i'm planning on cleaning it up, and use a little bit of fiberglass to create a physical barrier for the water. i'd also like to use it on the floorpans with some rusty metal primer plus a little fiberglass on a couple of the small footwell holes.
WHEEE!!1
Old May 1st, 06, 11:50 AM
1965prostreet 1965prostreet is offline
Tony
1965prostreet has a positive reputation
Default Re: rustoleum vs. por-15
i would personnally spend the money for the POR15. IMO its the best choice.
Old May 1st, 06, 12:52 PM
SHIFTY4 SHIFTY4 is offline
~the Sedan Man~
i went to the paint store ta get some "chassis black" paint... at 40 bucks a qt. i used rustoleum on my 68 c10 frame.
maybe it's not as good as the POR product... but i'll be pushin' daisies before it goes bad...
also known as...
JohnnyRotten
the FLYER
Old May 2nd, 06, 08:06 PM
62novaks 62novaks is offline
62novaks has a positive reputation
Ive used POR-15 for 3 diff restorations,and I beleive in it. John,I sealed the roof gutters on my 55 Belair with a liquid metal (Alvin Lab Metal) from a welding shop. I first etched it with a solution of Muratic acid,rinse with water,it kills the rust,and than filled the holes with the lab metal,using a paint brush,you can thin it,than used por-15,sanded and primed, and painted it. That was 4 years ago for the 55. Any way, Ive used it the same way for rusty floors etc. And yeah its expensive,but when your paint is $500/gal ,its cheap insurance.
Old May 2nd, 06, 09:00 PM
well, my paint is only going to run about 50-60/gal
maybe i should have iterated my intent - i'm trying to convert my nova from a field car look to a driver look. it had about 20 layers of rattlecan on it, and i'm looking to lay down maybe just a couple coats of primer, or whatever it takes to get smooth, then lay down some white to help hide the body work. maybe i'll put the side trim back, too. it's not a full-on restoration, i just don't want to look like i'm fresh out of the barn
with that in mind, yeah, i just wondered if it'd be enough to help me seal off some bad areas until i'm ready to replace the sheetmetal.
WHEEE!!1
Old May 3rd, 06, 03:53 PM
DANNO DANNO is offline
Dan
DANNO has a positive reputation
Another consideration is that POR-15 goes a long way. If it's not a large area just buy the starter kit. Do go through all the steps though. Prep is important.
Dan (POR-15 fan)
Old May 3rd, 06, 05:27 PM
CDJr CDJr is offline
CDJr
CDJr has a positive reputation
Well, if you insist on using POR-15, then you should at least check out Chassis-Saver by Magnet Paints, cuz its identical to POR-15 and is about $30-40 less per gallon. http://www.magnetpaints.com/underbody.asp
Old May 3rd, 06, 08:21 PM
72GreenRally 72GreenRally is offline
72GreenRally has a positive reputation
The site says MagnetPaints Chassis-saver is sensitive to UV light, and will change color over time if exposed to UV light. Is Por-15 UV light sensitive?
Randy (something that may need to be considered)
Old May 3rd, 06, 09:34 PM
CDJr
Yes, Randy, it is. They are identical, if you look at the tech sheets on both, youll notice theyre identical also.
Old May 3rd, 06, 09:52 PM
Nwayne Nwayne is offline
Nwayne has a positive reputation
I've used rust bullet with some really good results. It's tougher than POR 15, and doesn't require as much prep.
I've seen POR used and it peeled off about 8 months later.
Old May 3rd, 06, 11:20 PM
CDJr
Thats a big 10-4.....POR-15 and Chassis-Saver both are VERY particular as to what types of surfaces they will adhere to. The rougher, the better. Theyre not ideal for clean, smooth surfaces. But as far as rough, ROUGH surfaces, they are unbeatable. From my experience, Id suggest picturing a surface thatd be best suited for Play-Doh to stick to as being an ideal surface. It needs something to bite into for sure or it will just fall off.
Old May 3rd, 06, 11:56 PM
SS 396 SS 396 is offline
SS 396 has a positive reputation
I hate products that go OVER Rust
  #13
Old May 4th, 06, 09:58 AM
I was just holding chassis-saver the other day, but didn't buy it since i still had most of a pint of por-15 still sitting around.
i finally went to a paint and body supply shop for the first time, but i'll post that story in another thread.
WHEEE!!1
  #14
Old May 4th, 06, 11:40 AM
SixtyII SixtyII is offline
SixtyII has a positive reputation
Rustoleum chips way to easy. The last thing you want if you was to stop rust from reforming.
  #15
Old May 4th, 06, 11:45 AM
69NovaSS 69NovaSS is offline
Duane
69NovaSS has a positive reputation
from what I hear this stuff is as good, if not better, then Por-15 and it costs less too
http://www.nomorerust.com/
I havent used it myself but there are several members on Steves that have and they swear by it.
I spent a lot of money on booze, women, and fast cars; the rest I just squandered
