69 Nova mono to multi leaf springs - Nova Tech
Old Oct 7th, 07, 12:55 PM
cw41 cw41 is offline
Chuck
cw41 has a positive reputation
Default 69 Nova mono to multi leaf springs
I would like to convert my 10 bolt 8.2 mono leaf springs to multi and wonder if they will fit? I noticed there is a u-bolt and pad kit I can order for the conversion. Thanks again for the advice.
Chuck
Old Oct 7th, 07, 02:46 PM
nova_1972us nova_1972us is offline
nova_1972us has a positive reputation
Default Re: 69 Nova mono to multi leaf springs
Hi there, I did this change over to my 72 Nova recently. It went pretty smooth, I have a link to a site that I post pictures of my Nova on and I did post some pictures of the conversion if you would like to take a look. If you have and question please feel free to ask and I'll do my best to answer them. Later.
http://www.cardomain.com/ride/698916
Old Oct 7th, 07, 03:10 PM
You will need new spring perches in addition to the U-bolts to prevent the housing from rotating. The 8.2 inch ten bolt will not hold much power, it may not be worth the price of the new multi-leaf spring perches, and time to weld them on. An 8.5 inch corporate 10 bolt is your best buy. A Moser 12 bolt is the best solution, but not the cheapest.
Old Oct 7th, 07, 08:08 PM
Doug G Doug G is offline
Doug G has a positive reputation
www.JCWhitney.com has 3 leaf mono replacements that a lot of the Camaro guys are going to.
1972
Chevrolet
Nova 3-leaves, Leaf SpringZX942669XEach$69.99Will ship within 24 hours
68 Camaro~406ci
RedЯum <-Pics
11.304 @ 119.05 ~1320' NEW (3/19/11)
http://youtu.be/48OfD_C4JWU <-11.36 Vid.
Some days all you can do is just smile http://www.camaros.net/forums/images...es/biggrin.gif
Old Oct 7th, 07, 10:22 PM
Chuck
Thanks to all for the info. I have three rear ends that I got with the car but how do you tell which is the 8.5 as the rear cover appears to be the same on all of them, they could be 8.2's? They were all supposed to be from 68-69 Camaro's. Do I need to post the tube numbers?
On the JC Whitney springs did they come with the u-bolts and don't quite understand about the shims needed?
Old Oct 7th, 07, 10:38 PM
Cool Re: 69 Nova mono to multi leaf springs
This site explains all!
http://novaresource.org/axle.htm
Old Oct 7th, 07, 10:44 PM
Lead Slacker
If they are all origional 10 bolts from 68-69 Camaro then they are all 8.2" housings. These can be beefed up to handle moderate powered street cars, but the cost can be a little heavy and it becomes more cost effective to get a lower end 8.5" ten bolt that can handle some heavy duty street power and mid range track type power.
USA "One Nation Under God."
Old Oct 7th, 07, 11:03 PM
Chuck if you want an 8.5" I have one. If you pull it and put an 8.2 under the car to keep it rolling you can have it for free. I have tools, jacks and stands and concrete slab to work on. Needs to be done asap as the car has to go away.
Old Oct 7th, 07, 11:05 PM
BTW it is alreaqdy set up for multi leaf spring.
Old Oct 7th, 07, 11:27 PM
Chuck
Do any of the 8.2's have the pads for the multileaf or do I need the 8.5?
Thanks for the offer of the 8.5 freebee, what car is it on that you're needing to get rid of?
Thanks for the wealth of info on the rear ends I'll print it.
Chuck
Old Oct 8th, 07, 12:12 AM
I have 2 75's both with 8.5's. One is a 2.73 the other a 3.08. Cars are going away in the next month. Where in AZ are you?
Old Oct 8th, 07, 02:04 PM
Chuck
Phil I'm up north in Winslow are you selling the 75's, if so what kink of shape are they in? Thanks,
Chuck
  #13
Old Oct 8th, 07, 09:20 PM
I used to live in Snowflake and then in Lakeside.
The hatchback is tenativley sold to a guy in Texas and supposed to be pickup this month. I have no money yet and have not heard back from him. I need to call him tonight and check on this. It is missing the tailights and headlamp bezels. The other is an untitled parts car and would not be worth trying to put back together.
  #14
Old Oct 9th, 07, 09:09 PM
strtlegal strtlegal is offline
chuck
strtlegal has a positive reputation
the visual difference ive noticed from the 8.2-8.5 is the back pan..the 8.2 looks like a 12 bolt cover meaning it has that raised lip in the center and the 8.5 has damn near a perfectly round pan with no indentations on it....
ive owned a hand full of novas and i've personally never scene a 8.2 with multi leafs..
and i think the 4th gen nova rear end is to long, its needs to be 53" backing plate to backing plate..normally a 73-74 nova came with the 8.5" some 71-72's but rarely.
MY 70 NOVA, LS2, Tremec, ATS spindles, Speedtech Chicayne kit, C5 brakes, QA1's, Alston G-link....lowered extensively
http://i25.photobucket.com/albums/c8...s/100_3212.jpg
  #15
Old Oct 9th, 07, 09:59 PM
Lead Slacker
Here are pictures of each of the 10 bolt rear ends
71 was the last year the 8.2" ten bolt was used in the nova and the last year you could get a 12 bolt. Starting in 72 the only rear end available for the Nova was the 8.5" ten bolt and the dimensions stayed the same through the end of production. In 76 the 7.5" ten bolt became the standard rear end for the Nova, but it could still get an 8.5" depending on options chosen. But all the rear ends used in 68 to 79 X-body cars had the same dimensions and could be used as direct swap rears. Also the 67-69 F-body car rear ends had the same dimensions and are directly interchangeable. Just be careful you do not end up with the 7.5 ten bolt or one of the BOP rear ends as I know for a fact the 68 Firebird 10 bolt was a completely different beast it had C-clip eliminators and looked nothing like the standard 10 bolts and none of the parts interchange.
Were To Go Trace Car Back 69 Nova Ss jus4tzn Tag Team 5 Sep 2nd, 07 05:38 PM
Body Panel Fit - 69 Nova SS tim68rsss Body Shop 7 Aug 10th, 07 02:50 PM
nova coil springs 71Nova400 Brakes & Suspension 4 May 14th, 07 02:20 PM
69 Nova Subframe Spacers classiccamaro Restoration Corner 8 Nov 9th, 06 10:22 PM
question, 76 nova coil springs compatabillity johndaddy Brakes & Suspension 4 Jun 14th, 06 05:05 PM
