Short Deck 454 - Nova Tech
Old Sep 19th, 07, 02:20 PM
ChevyGuy ChevyGuy is offline
ChevyGuy has a positive reputation
Default Short Deck 454
I have a question about 454 blocks. As best as I can tell they came in 3 different deck heights.
The Tall deck which was designed to handle pistions with 3 compression rings 1 oil ring.
The Standard deck used in passenger cars designed to handle pistons with 2 compression rings and 1 oil ring.
The short deck is the one I can't find any info on. What is it used for?
Which of the 3 is best to build a performance engine with?
Thanks any info would help!
Old Sep 19th, 07, 04:05 PM
Cool Re: Short Deck 454
Close, but no cigar. Std deck is a Passenger (Pass) or HiPerf automobile and light truck engine with two compression rings and one oil ring. The Truck block is also known as a tall deck because it is 0.400" inches taller than a car block (9.800"+0.400"=10.200") to accommodate three compression rings and one oil ring. In the after market there is a taller deck (11" and above) that allows a stroke of up to 5 inches. Number of rings are optional but the piston pin is usually in the ring pack.
Though on second thought there is a "ProStock" block that has a 9.00" deck height and 5" bore spacing to accommodate a big bore and short stroke motor for those leisurely 10 grand shifts. (Olds BowTie DRCE block)
Old Sep 19th, 07, 10:07 PM
Default Re: Short Deck 454
GM produced 2 versions, standard and tall. Tall only being used in large 1.5 ton and up. If looking for a 454 for your car any engine from a 1 ton truck down to a passenger car will have the correct block. Heads would be best off of a passenger car motor or aftermarket.
77 Nova, 406, TKO 600, 3.73 8.5" 10 bolt
Old Sep 22nd, 07, 12:54 AM
Motorhead62 Motorhead62 is offline
Motorhead62 has a positive reputation
Talking Re: Short Deck 454
A standard deck style engine is best in a street driven car. The 2 or 4 bolt main 454 block is a great foundation to build upon. Always build the largest displacement engine you can afford and you can make the most torque possible on a budget.
1967 Chevelle - 496BB/TH400/Dana-60
1967 El Camino - 388SB/700R4/12-Bolt posi
1967 C-10 - 462BB/TH400/12-Bolt
Chris @ www.C-DPerformance.com
Old Sep 22nd, 07, 11:06 AM
Lead Slacker
Then there is the 454 Small block Chevy Hard Core made for a while! Some one may have refered to it as a short deck 454.
USA "One Nation Under God."
Got My Deck Lid Stripped nogo69 Body Shop 3 Jul 7th, 07 11:09 AM
454 plug gap 70ssBB Engine 1 Apr 24th, 07 06:42 PM
454 engine mount detailed answer needed 70ssBB Engine 6 Dec 23rd, 06 03:01 PM
454 head casting #S 70ssBB Tag Team 2 Nov 17th, 06 08:58 PM
Short video clip of my Nova idling DriveWFO Performance 10 May 6th, 06 10:30 PM
© 2009 AutoForums
