Novas.net is the premier Chevy Nova forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Engine General Engine Discussion
Old Jun 27th, 07, 07:01 PM
71Nova400 71Nova400 is offline
71Nova400 has a positive reputation
Default 64cc heads on 406SB
I am planning on building a 406SB. i have popped up pistons, stock crank, and stock heads. The part that I am debating about, is if I went with the 64cc Camel Hump 2.02 heads...will that be beneficial to the build? Is there a noticeable difference? Should is stick with the 76cc stock heads? I know it won't be pump gas friendly, but it will be mostly a weekend car.
Any information would be great.
thanks
So-cal Jack
Old Jun 27th, 07, 10:39 PM
67SS&99SS 67SS&99SS is offline
67SS&99SS has a positive reputation
Default Re: 64cc heads on 406SB
If you are wanting a real performance motor, save up for some quality aftermarket heads. 200cc Dart Iron eagles would net you significantly more power than the camel humps. Those heads were designed in the mid 60s for corvette 327s, then later found their way on 302s and 350s. I don't think that they will flow enough air in the upper rpms to really let your 400 breathe. My friend has a set of camel humps on his 406 and all he talks about is saving enough money for some aluminum AFRs or Trickflows. You could also run a 72 CC head and not have to worry so much about the compression jump from 76CC to 64 CCs.
1967 Camaro SS 350: 406, 510hp/505 ft lbs|M20|3.73s|posi
1969 C/10: 350|Turbo 350
1972 Nova: 350|Turbo 350
1974 'Cuda: 340|4speed|Dana 60
1999 Camaro SS: LS1|Auto|LTs|True duals|TT2s.
Old Jun 28th, 07, 11:15 AM
what vehicles have 72cc??
Old Jun 28th, 07, 03:39 PM
Villain281H Villain281H is offline
Villain281H has a positive reputation
Send a message via AIM to Villain281H
Another opinion for running an aftermarket head versus the camel hump (saves those for the resto). You can see a 40-60 hp improvement with a good set of aftermarket heads over stock ones, and I'd go aluminum for weigh savings and heat (a good thing to check out on a 400 engine). Canfields are what I'm running on my 383, but a ton of them are out there!
Derek
1970 Nova SS Clone
Just another average pump gas small block "show car" with a glove box full of timeslips
www.fquick.com/villain281h
Old Jul 3rd, 07, 07:44 PM
Another option is save your money for a Vortec aluminum Performer RPM manifold and instead bolt on some Vortec Chevy cast iron heads. It will have the open chamber you need to run pump gas (a 406 with flat tops and a 64 cc head is running 11.0:1 static compression, with pop-ups your looking at race gas only) and will breath as well as 60% of the best aftermarket heads at half the price.
vortec heads flyinmonkeys32 Performance 41 Jul 11th, 07 12:47 AM
over worked heads? Mr. 1975 nova Engine 3 Oct 27th, 06 05:24 PM
Installing new heads. 71Nova400 Engine 14 Oct 7th, 06 10:41 PM
Sandblasted heads 71Nova400 Engine 2 Sep 3rd, 06 01:44 PM
302 w/289 heads creat motor ws6transam Engine 6 Mar 20th, 06 10:22 PM
© 2009 AutoForums
