67 chevy 11 bellhousing? - Nova Tech
Old Oct 8th, 11, 08:30 PM
Smblkvega1 Smblkvega1 is offline
Steve
Smblkvega1 has a positive reputation
Default 67 chevy 11 bellhousing?
Just picked up a 67 chevy 11 its a 6 cylinder standard trans. Will this bellhousing fit a sbc engine? Thanks Steve Uncasville Ct.
Old Oct 8th, 11, 11:40 PM
Default Re: 67 chevy 11 bellhousing?
yes the bell housing bolt pattern is the same on the inline 6, small block and big block.
Old Oct 9th, 11, 12:25 AM
modernperformanceclassics modernperformanceclassics is offline
Team Member
Steve
modernperformanceclassics has a positive reputation
I don't think that is correct. I believe that the center hole is too small. The small block and 6-cylinder are different sizes and will not interchange.
Old Oct 9th, 11, 01:38 AM
Carl Stevenson Carl Stevenson is offline
C
Carl Stevenson has a positive reputation
You should be ok with the 67 bellhousing. As far as I've seen, only the 62 63 64 bellhousing has the small hole.
Does the casting number on it end in 309? If so, you are good to go.
Old Oct 9th, 11, 10:20 AM
The central hole size increased in diameter to accept the Muncie four speed (introduced in 1963, but the four speed wasn't used on a six cylinder) so a 1964 V-8 manual transmission application should have the larger hole. As stated above from 1965 up all bell housings interchanged as they had the larger hole, because of GM's one part rule.
Old Oct 9th, 11, 11:17 AM
The question was will it fit the engine block, but in 67 GM was using a 3 speed Saginaw as the standard manual transmission. That transmission had the same size bearing retainer as the 4 speeds.
Old Oct 9th, 11, 02:33 PM
SHIFTY4 SHIFTY4 is offline
~the Sedan Man~
depending on the casting number the sixer bell may or may not work with a Muncie 4spd. the bearing retainer hole for the sixer trans is smaller than that on a "309" housing (V8 housing)
here's a couple pics, some i STOLE!!!
also known as...
JohnnyRotten
the FLYER
Old Oct 9th, 11, 06:01 PM
C
You are right about the 64's. I was completely wrong about the year. The GM parts book says all 64's have the correct bellhousing. Only 62 and 63 are the small one according to the book.
Old Oct 9th, 11, 07:40 PM
Steve
Thanks for the relpys that will be great if i can use it save a lot of trouble
to find one. I will check out the number on it. Thanks Steve
Bellhousing for 68-80 smallblock? ARE1971355 Driveline 27 Dec 23rd, 09 11:39 PM
Cracked Bellhousing tpr_pjones Driveline 8 Nov 23rd, 09 07:59 PM
Which bellhousing do I need? HYPOWER63 Driveline 2 Jul 19th, 08 06:37 PM
Dialing in a bellhousing 1quik69 Engine 4 Feb 5th, 08 12:09 PM
350 M20 Bellhousing Help tim68rsss Driveline 1 Jun 2nd, 07 04:11 PM
