74 Nova Compatible Front Clip - Nova Tech
Old Jul 12th, 10, 07:25 PM
mrmikev1 mrmikev1 is offline
Mike
mrmikev1 has a positive reputation
Default 74 Nova Compatible Front Clip
Newbie here and tried to research back but did not find anything. I would like to know what cars are compatible with the 74 Nova front clip. Mine is stock with drum brakes, straight 6, no power steering. I want something that will have the disc brakes, power steering hardware and v8 mounts. I am hoping to find some cheap junker (non-desirable that has what fits) that has the components I need. I am new at this, was told it could be done but don't know how to find the answer. Any help would be great, thanks in advance!
Old Jul 12th, 10, 09:20 PM
Default Re: 74 Nova Compatible Front Clip
67 - 69 Camaro and Firebird and 68 - 73 Nova will interchange. The 74 Nova is a little different where the front bumper mounts, but will bolt to the body the same.
Power steering, V8 engine and disc brakes can be added to the subframe you have.
Old Jul 12th, 10, 11:02 PM
There are also custom hydraformed front sub-frames designed to take any motor and utelize unequal length A-arms and disc brakes with Corvette sized rotors and powered rack and pinion steering with fully adjustable coil over shocks and adjustable front sway bars (for a bit more than you'd pay for a junk yard part).
Old Jul 12th, 10, 11:27 PM
Mike
Philip/Big Dave - thanks for the replies. It seems that the Camaro and Nova years may be harder to come by and pricier as they are the more desirable years. I was told there are other Chevy/GM (75 or later Caprice, Monte Carlo, etc) cars that are not 'desirable' that have a compatible front clip, is that wrong?
Philip, you also state that they could be added to my subframe - would that require welding or is it bolt on stuff? I am trying my best to keep this all bolt on stuff as welding is not my strong suit and would have to be tasked out to someone.
Thanks again for the help.
Old Jul 13th, 10, 12:06 AM
Your 1974 has a modified 1968-'74 front sub-frame. The modifications to the sub-framer where made to mount your big bumpers, and to bolt the motor down so that it can not break a motor mount. Both of these modifications occurred in the 1973 model year and where mandated by federal law. Your front end is a rear steer design. That is, the tie bar and the steering gear box are behind the front spindle.
On 1975-'79 Novas they used the 1970-'81 second generation Camaro front sub-frame that fixed the problems Camaro owners had discovered in racing the same front end you have (severe bump steer, and caster/camber problems associated with body lean). The fourth Gen Novas all have front steer so the steering gear box is out of the way of installing a big block, and the track is wider with better steering geometry achieved by redesigning the A-arms.
Any 1968-'74 Nova front end can be a donor for parts. I suggest you read this article from our sister site
http://www.camaros.net/techref/articles/ftecref012.html
and check out David Pozi Racing’s web page linked to Team Camaro for more information.
For disc brakes parts you can use:
Suitable Donor Vehicles
  • 1969-1974 Nova
  • 1973-1974 Omega
  • 1971-1974 Ventura II
  • 1973-1974 Apollo
  • 1969 Camaro
  • 1969 Firebird
  • 1969-1972 Chevelle
  • 1969-1972 LeMans
  • 1969-1972 Cutlass
  • 1969-1972 Regal
The donor cars would be 1969-'72 GM A-body and X-body cars that have two-piece spindle assemblies. These spindles have a removable steering arm. These are easily distinguished from the later one-piece spindle design.
Donor Parts Required
  • Master cylinder
  • Proportioning valve
  • Proportioning valve bracket
  • Short steel lines from m/c to prop. valve
  • **The line fittings in the prop. valve**
  • Spindles
  • Calipers
  • Rotors
  • Backing plate
  • Steering arms
Old Jul 13th, 10, 07:34 PM
Blown73 Blown73 is offline
Jeff Hayes
Blown73 has a positive reputation
It might be easier for you to find the parts you want and put them in. Your subframe should currently have the holes for a SBC mount. You can find old camaros with power steering and swap that out as well. Or, buy a new steering box. You can get disc brake spindles from the junkyard also from any of the cars listed by big dave and make the swap over also.
I think that would be a lot less labor-intensive...
You can never have enough horsepower or ammunition
http://www.novas.net/forums/showthread.php?t=19521
Old Jul 14th, 10, 03:18 AM
Mike
Thanks again to the three of you, you have given me plenty to chew on. I will digest this and start tearing into things a bit. If I run into problems you will hear from me again (probably even if I don't). This is a great site and I will be in touch. My plan is to look into getting parts from the cars Big Dave listed (I liked the acronym by the way )
Thanks again, I will be back...
Old Jul 15th, 10, 03:01 PM
Mike
Do you have a picture of the two? They may be easily distinguishable but I need to know which one I am looking at. Is my '74 with drums a one-piece or two-piece?
Remember, I am new at this, but if I see it I can learn it.
Front Clip question chevyboy_0 Brakes & Suspension 3 Mar 10th, 09 06:14 PM
1966 Chevy Nova Front Clip install 1bad66ss Nova Tech 2 Nov 11th, 08 01:56 PM
front end clip red nova Brakes & Suspension 5 Jul 28th, 08 12:38 PM
1964 Front Clip chpmach Body Shop 1 Jun 22nd, 08 11:53 PM
new front clip lrisner Brakes & Suspension 1 Sep 13th, 06 02:45 PM
© 2009 AutoForums
