speedometer cable? - Nova Tech
Old Jun 21st, 10, 04:39 PM
bowhuntermark bowhuntermark is offline
mark
bowhuntermark has a positive reputation
Default speedometer cable?
I have no speedometer cable in the car right now. I just had to purchase a new B+M turbo 400 callsic ind. tells me a factory replacement cable will not work. I need to know the thread size on the panel if there is one so I can possibly order a lokar cable. Thanks mark
Old Jun 21st, 10, 07:20 PM
Blown73 Blown73 is offline
Jeff Hayes
Blown73 has a positive reputation
Default Re: speedometer cable?
Do you have a stock instrument panel or aftermarket? Stock I believe is a slip on with a retainer clip while aftermarket guages are typically threaded....
You can never have enough horsepower or ammunition
http://www.novas.net/forums/showthread.php?t=19521
Old Jun 22nd, 10, 12:03 AM
The stock cable should fit the transmission; every GM car I have seen uses the same size threaded end. The dash end can be different, starting around 68 or 69 the dash connection was changed to a slip on from the earlier threaded style. If using an aftermarket speedometer with a threaded connection a cable from an earlier car will work. I am using a cable for a 67 Camaro in my Nova.
right angle speedometer cable adapter ARE1971355 Troubleshooting 17 Jun 10th, 11 11:59 PM
speedometer help bowhuntermark Nova Tech 2 May 31st, 10 10:58 AM
Speedometer Cable DrededSS Driveline 1 Jan 6th, 10 07:32 PM
speedometer cable tdawglp Driveline 7 Dec 27th, 09 10:57 PM
Speedometer cable question seitzman Driveline 4 Apr 26th, 09 10:45 PM
