Performance High Performance!
Old Oct 30th, 09, 10:57 PM
JeffersonC JeffersonC is offline
Jefferson
JeffersonC has a positive reputation
Default 492 "Performance Heads" I Came Across
Just searching around ebay to see what prices go for on the 492s as I have a pair and came across these Crane Cams 1970 ones. Anyone ever heard of these? The ports look huge! Worth picking up? The guy is close to me.
http://cgi.ebay.com/ebaymotors/Chevr...028191001r4908
Old Oct 30th, 09, 11:38 PM
brian oneil brian oneil is online now
Senior Tech Team *
brian oneil has a positive reputation
Default Re: 942 "Performance Heads" I Came Across
"The best small-block Corvette heads include the following:492 (double hump)-The prototypical double-hump, cast-iron, small-block head is casting number 3991492. The double hump or "camel hump" casting marks can be found on a variety of small-block iron heads and designate a high-performance casting. Many heads with the double-hump mark were installed on fuel-injected Corvette engines, dating back to 1960. As a result, 492 and other double-hump castings are routinely referred to as a fuel-injection or fuelie heads, even though they were also used on the original LT-1 and the 302ci Z/28 Camaro engine. Common features include 2.02/1.60-inch valves, 64cc combustion chambers, and 160cc intake runner volume. As part number 3987376, this head featured screw-in rocker arm studs and pushrod guide plates. But as part number 3958603 (discontinued in 1991), a 492 casting had pressed-in studs and was machined for 1.94/1.50-inch intake/exhaust valves."
By Dave Emanuel
As long as they are not cracked, they may be worth the money. Dart Iron Eagle may be just as cheap once all the machine work is done and all parts are bought. Kinda hard for 70's tech to outflow modern design.
71 Nova
408 SBC
7.207 Second 1/8 Mile
Old Oct 31st, 09, 02:10 AM
Jefferson
Of course it would be cheaper to buy a new set of heads and be done, but to have a probably limited run of classic performace heads would be sweet to have/rebuild.
Big Dave or any of you guys ever heard of these?
Old Oct 31st, 09, 08:51 AM
Those heads have been professionally ported but they will need a valve job as at least one aftermarket hardened seat has fallen out already due to a bent or broken valve (nick in the chamber next to the missing valve seat were the valve head kissed the piston and broke off to hit the head). They have probably been angle cut at least once which reduces any chance of milling them flat if they are warped, it also promotes cracking in between the two holes at the spark plug quench supply as the metal is thin and unsupported (so have them magnafluxed for cracks).
So far you are paying 1/3 the price of a new aftermarket head (which can be machined to have a double hump front ID pad to attempt to disguise your aftermarket head) plus shipping. You need to pay to have them magnafluxed a new seat and a valve job and at least one guide will need replacing so I would say you are already talking 4/5 the way to an aftermarket head for a used head that will not flow as much and may still be unusable because of undetected cracks. That added to the fact that there is three days of bidding to go and sniper software could drive it above your max at the last second (making you miss out on the Halloween special on at least two aftermarket head manufactures who are offering Spook-Tacular buys on heads right now.
Old Oct 31st, 09, 10:19 AM
Senior Tech Team *
Originally Posted by Big Dave View Post
drive it above your max at the last second making you miss out on the Halloween special on at least two aftermarket head manufactures who are offering Spook-Tacular buys on heads right now.
Good one Dave
71 Nova
408 SBC
Old Oct 31st, 09, 12:31 PM
Jackel Jackel is online now
Jack
Jackel has a positive reputation
If you win the bid at your calculated price it would be a nice head for a period correct motor build. I think the 100 HP extra claim seems to be exaggerated. If you have the spare coin, it would be a great project for you to document, maybe even do a article based around the build. Jackel
Retired Bum, The Transition Was Easy
Old Oct 31st, 09, 01:56 PM
SHIFTY4 SHIFTY4 is online now
JohnnyRotten
SHIFTY4 has a positive reputation
i've got a set of Humpers here at home... professionally done in the early '80's. a set of 291's. ported/polished, cc'd to 68, 1.94's & 1.625's with guide plates & studs.
JollyRodder.com
HotRod Web Links & Tech Info
Old Nov 7th, 09, 11:53 AM
Jack
Jefferson, did you buy the heads? Jackel
Old Nov 7th, 09, 03:12 PM
Jefferson
No I didn't unfortunately they came up just under 400$ which was a little too much for me
holes next to exhaust ports on 350 heads rustybucket Engine 6 May 14th, 09 04:13 PM
041 heads? jmcfalls Engine 2 Oct 2nd, 08 12:00 AM
Big Block cylinder heads i_dunno_09 Engine 5 Aug 25th, 08 10:52 PM
GM Performance Parts Vortech Heads? jones66ss Performance 3 May 20th, 08 10:36 PM
3998993 Heads nogo69 Engine 4 Jul 4th, 07 03:21 PM
