Old Nov 2nd, 09, 07:23 PM
ovrdrive ovrdrive is offline
Dan
ovrdrive has a positive reputation
Default Rear end gear change
Ok guys and gals, here's one fer ya...
I am going to swap out the 4.10 gears with some 3.55 for better highway driving in the car and was wondering on the following:
Besides swapping out the gaskets, could I reuse the shims off the ring and pinion ( 4.10 ) for the new gears?
I will replace the crush collar and was wondering if the shims were a one time use only.
If there is anything else that I need, please let me know..
1966 Chevy II 2-door
355 390hp
200-4R 22-2500 stall
4.10 posi
http://www.youtube.com/user/dty1996
Old Nov 2nd, 09, 09:08 PM
Default Re: Rear end gear change
They are reuseable but your new gear may need different shims (they are all fixed in thickness and can be stacked to get the required spacing). The shims you need can be bought with a rebuild kit (a package of various thicknesses). The thickness you need is written on the new gear set after you determine what the dimensions are before you take it apart a little math will tell you what you need to set it up correctly.
Old Nov 2nd, 09, 10:20 PM
Dan
Thanks Big Dave.. Which dimensions are you talking about? The depth of the pinion in reference to the ring gear or the spacers needed under the ring gear? Its been about 5 yrs since I rebuilt this rear end and need all the help possible.
355 390hp
4.10 posi
Old Nov 2nd, 09, 11:15 PM
big gear head big gear head is online now
Freddie
big gear head has a positive reputation
Anytime that you change a part in the rear end you will have to go through the process of setting the epinion depth, backlash and bearing preload all over again. This is going to require a different shim set almost every time. I've built hundreds of rear ends and only 2 times have I been able to use the original shims again.
Moser Engineering Dealer
http://www.camaros.net/showroom/show...00&ppuser=1922
Old Nov 3rd, 09, 09:17 AM
There are about thirty different thicknesses of shims. I recommend keeping every shim you can find and marking it's measeared thickness and storing it in a plastic zip-lock bag to keep it from rusting between builds (unless you are like Freddie or my best bud Robert who builds them all the time and just puts them on a peg board with the thickness marked beneath it). I gave my shim collection to Robert as I gave up on building anymore rear ends due to a pronounced lack of patience on my part (I am too easily frustrated now that the rewards don't seem as great).
Old Nov 3rd, 09, 09:31 AM
higleyml higleyml is offline
Mike
higleyml has a positive reputation
Dan wasnt that the purpose of the 700 r4? That should give you the best of both worlds, the 4:10 for pulling the hole shots and the forth gear for highway driving.
Mike
Old Nov 3rd, 09, 11:11 PM
Dan
Remember Mike, the 200 has a moderate 1st gear and having some fun getting out of the hole but, as of right now, I am just doing some research on this for the possibility of a change.
355 390hp
4.10 posi
63 Vert rear end question rs1968ss Brakes & Suspension 11 Aug 6th, 09 08:35 PM
Bringing up the rear Big Dave Driveline 8 May 18th, 09 11:13 AM
What Have I Got? Big Dave Driveline 1 Nov 8th, 08 03:36 PM
70 nova rear end upgrade??? fjas70 Driveline 9 May 13th, 08 07:01 PM
