Old Oct 29th, 09, 01:47 PM
EL TATE EL TATE is offline
Tate
EL TATE has a positive reputation
Default Rear axle shafts
Hello to everyone here, I'm coming to you in desperation, as I have a customer that has come to me with a very odd application; 1975 chevrolet nova with 26 spline axle shafts. all of my information leads me to 28 spline axles that are 29.5" from outside of flange to the tip of the shaft at an angle. he's counted 3 times and still comes up with 26 spline, but the correct length. have any of you encountered or heard of a nova with this setup? I've come accross an application in 1977 that had the smaller 7.5" diff and that would have 26 spline axles, but no information on length. any help would be greatly appreciated.
Thank you,
Old Oct 29th, 09, 02:43 PM
Default Re: Rear axle shafts
Welcome to the Team Tate!
The 28 spline 10 bolt 7.5 inch (or 7-5/8 inch) rear end was used in 1976 and up Nova six cylinder cares. They used the same ring gear size with a smaller 26 splines axel in later model third generation Camaro cars so some one transfered the wrong rear under the car in an effort to get a posi or gear ratio that they wanted. Check for cut off coil spring brackets and poorly welded leaf spring perches to confirm my theory. The axel application (length) will be for a 1982-92 Camaro.
Old Oct 29th, 09, 03:28 PM
Tate it sounds like your customer has a 7.5" differential. Even though 75 may have left the factory with an 8.5", 28 spline set up in the last 34 years someone may have changed it.
Have him compare this chart to his application
Old Oct 29th, 09, 05:10 PM
69X11SS 69X11SS is offline
Jim
69X11SS has a positive reputation
That axle is not out of a Camaro. Starting in 1970 the Camaro axles were longer than the Nova.
There is a fine line between hobby and obsession and I think I crossed it!!
69 Camaro SS 350 5 Speed
69 Corvette Convertable 350 4 Speed
71 Nova 350 4 Speed (Son's car in Dad's care while he is deployed)
Bringing up the rear Big Dave Driveline 8 May 18th, 09 11:13 AM
Rear axle help cwmccabe Driveline 2 Apr 29th, 09 08:13 PM
finding the right rear axle xrider69 Driveline 14 Dec 6th, 08 12:21 PM
rear axle shock plates soundman Brakes & Suspension 9 Dec 1st, 08 07:43 PM
Rear Axle housing ID. Gloryhound Tag Team 17 Jun 22nd, 06 10:59 PM
